![]() | Home > My Defender > Just Joined |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2661 ![]() ![]() ![]() |
WTF!? ![]() ![]() ![]() ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
busdriver Member Since: 12 Oct 2011 Location: Hampshire Posts: 45 ![]() ![]() ![]() |
Hi
Muddy Mark - The heated mirror switch is actually a Spot Light switch, YUG000350LNF. That got me a blank switch with no label on it, then i got a set of switch labels from vehiclewiringproducts.co.uk ref:SYM, they are on a transparent sheet so i took the heated rear window sticker and cut it out and rotated it 90 degrees. I was in a rush and didnt cut it as tight around the symbol as i could have so next time i order something from them i'll get another sheet and do it again, they are only £1.62 a sheet. Don't know what i'm going to do with the other 148 symbols on the sheet!! ![]() Naks - I'll try and do something over the next week for you. If you are keen to do it then the main tool you need is something similar to a Dremel with some cut-off discs to attack the fascia with. Also pick up some sheets of perspex, A4 size should be enough 1.5mm & 3mm thick & some PVC solvent weld cement. If it sounds a bit heavy going I'll make you one up for a lot less than 900Euros!! ![]() From my experience of fitting the unit, if you decide to buy the one from the german site make sure it fits the stereo you want to install. I made mine to take the full double din unit including the surround with a standard double din cage whereas i can see theirs just takes the head unit with their own double din size cage. I also wanted to keep the hazard light switch on the centre, i didn't want to cut into the fascia sides as they have done as i preferred mounting the window & heated seat switches on the cubby box which feels more natural anyway. There are a few minor alterations you have to make to the dash, mainly the clock & original radio support. I'll dig out the photos and get typing. Phil |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 ![]() ![]() ![]() |
I'll keep a look out - i'm only 8 miles from fordingbridge |
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 ![]() ![]() ![]() |
busdriver, did you ever make a how to or anymore info on the double din....
i am going to make one or i would be happy to pay you..... ![]() |
Chad
I have sent you a pm |
AleksTkach Member Since: 26 Jun 2022 Location: stuttgart Posts: 1 ![]() ![]() ![]() |
Hello. What offset are these wheels? Have you lifted the suspension?
