Home > My Defender > Just Joined
Page 3 of 3 <123
dgardel wrote:
http://www.audioexclusiv.ch/news/defender_doppel-din-umbau/
900,00€ Shocked Shocked Shocked Shocked Shocked
that was it, great value Shocked ... cheers Daniele
Steve
Post #102069 23rd Nov 2011 7:56pm
Naks
WTF!? Shocked Shocked Shocked Shocked --
Post #102078 23rd Nov 2011 8:31pm
busdriver
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Tonga Green
Hi
Muddy Mark - The heated mirror switch is actually a Spot Light switch, YUG000350LNF. That got me a blank switch with no label on it, then i got a set of switch labels from vehiclewiringproducts.co.uk ref:SYM, they are on a transparent sheet so i took the heated rear window sticker and cut it out and rotated it 90 degrees. I was in a rush and didnt cut it as tight around the symbol as i could have so next time i order something from them i'll get another sheet and do it again, they are only £1.62 a sheet. Don't know what i'm going to do with the other 148 symbols on the sheet!! Confused
Naks - I'll try and do something over the next week for you. If you are keen to do it then the main tool you need is something similar to a Dremel with some cut-off discs to attack the fascia with. Also pick up some sheets of perspex, A4 size should be enough 1.5mm & 3mm thick & some PVC solvent weld cement. If it sounds a bit heavy going I'll make you one up for a lot less than 900Euros!! Shocked
From my experience of fitting the unit, if you decide to buy the one from the german site make sure it fits the stereo you want to install. I made mine to take the full double din unit including the surround with a standard double din cage whereas i can see theirs just takes the head unit with their own double din size cage. I also wanted to keep the hazard light switch on the centre, i didn't want to cut into the fascia sides as they have done as i preferred mounting the window & heated seat switches on the cubby box which feels more natural anyway. There are a few minor alterations you have to make to the dash, mainly the clock & original radio support.
I'll dig out the photos and get typing.
Phil
Post #102092 23rd Nov 2011 9:07pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
busdriver wrote:
I kept the wheels off my old Defender but it was a bit if a headache getting them to fit, I ended up raising it a bit with OME springs. I designed & made the dash myself, couldn't find anything out there that did what I wanted.
David. I'm the opposite side of Hampshire to you I think, near Fordingbridge.
I'll keep a look out - i'm only 8 miles from fordingbridge
Post #102220 24th Nov 2011 4:14pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
busdriver, did you ever make a how to or anymore info on the double din....
i am going to make one or i would be happy to pay you..... Smile
Post #148476 3rd Jun 2012 8:46pm
busdriver
Chad
I have sent you a pm
Post #148714 5th Jun 2012 1:16pm
AleksTkach
Germany 2011 Defender 90 Puma 2.4 CSW Orkney Grey
Hello. What offset are these wheels? Have you lifted the suspension?
Post #956591 26th Jun 2022 2:43pm
Page 3 of 3 <123
