Home > Puma (Tdci) > Starting Issues (Fuel Pressure?) |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17353 |
Part number is LR006865, a cool £370 or thereabouts (note my comment above).
11th Jan 2024 11:26pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1988 |
This topic is worth a read, it covers PRV replacement, however in the end it seems it was not a PRV but VCV issue.
https://www.defender2.net/forum/topic80592.html?highlight=prv |
12th Jan 2024 12:18pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2295 |
Unclip the fuel return hose off the back off the PRV then crank it. If the PRV is spewing fuel then it's gone and needs replacing (it is a friction fit ball bearing that pops out so not resettable)
I am inclined to agree I would change the VCV again for known genuine trustworthy one (read here https://www.defender2.net/forum/topic85644.html) Read my post here about a costly wild goose chase that turned out to be a VCV https://www.defender2.net/forum/topic53240-245.html > 110 XS Double Cab |
12th Jan 2024 1:21pm |
khamuul Member Since: 14 Oct 2017 Location: Teutoburg Forest Posts: 24 |
You could try febi bilstein 46366 for the PRV/OPV/PLV/howisitcalled. (~90€ online)
Workshop manual says:
"faulty VCV" = "malfunctions in the high-pressure system"... |
12th Jan 2024 2:49pm |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 361 |
This erratic behavior actually points to the VCV. Possibly also the crankshaft sensor. |
19th Jan 2024 5:04pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20300 |
The VCV does cause very erratic behaviour, I do know for a fact that my last one was killed of by moisture or some water in fuel…
I know because I used a fuel station I have never used since as a one off, after filling up there a couple of days later it cut out after being started multiple times and things like that. It was definitely after filling up at that fuel station, and a new VCV and fuel from another fuel station cured it. I used up most of the fuel with the old VCV first, but there must have been water in the diesel, that I do know as a fact, and it killed the VCV. Probably leaky old underground forecourt tanks I expect. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
19th Jan 2024 5:13pm |
