Home > Maintenance & Modifications > Diff/Transfer case oil - EP80/90 GL4 or GL5 |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2418 |
Defenetly way diiferent from a typical 80W-90
Puma 110" SW ............................................................. Earth first. Other planets later |
4th Jan 2024 12:12pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3299 |
I’ve been using Swepco for a few years now and will continue to do so as it was recommended to me but ’reassuringly expensive’ is a fair description. WARNING. This post may contain sarcasm. |
4th Jan 2024 12:46pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2234 |
Thanks MK, what exactly is that telling me about how it's better than other oil ? Sorry, I don't know much about oil properties ! Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
4th Jan 2024 1:16pm |
I do not know if it is better, but both viscosities (at 40 and 100C) are way way lower than a typical 80W-90 (let´s say 20 and 150 cSt vs 7.19 and 37.9 cSt). So it is something radical, different testing method or there is a mistake in their publication. I cannot tell. Puma 110" SW
4th Jan 2024 1:37pm |
Interesting ! But could lower viscosity not be a bad thing ? Surely then it's acting like a less viscous grade of oil than the recommended ? Could the same thing not be achieved by just putting cheaper thinner viscosity oil in there in the first place ?
It certainly seems to be a minefield and I'm unconvinced that Swepco oil is worth the additional expense especially as it appears to act like a grade of oil not recommended and so could be detrimental ! I'll continue with Ashcrofts recommendations. Thank you gentlemen for your thoughts. Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
4th Jan 2024 2:08pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
What makes one oil better than another?
I think to the normal user, primarily would be the sound an engine, or since the subject is about gear oil, a diff would make. In case of a gearbox, you would add the easy of gear change. When the LT77 was released, Rover specified ATF for ease of gear change. Its not because its was a better oil to protect bearings, synchros or gears! And as mentioned earlier, what warranted a change if viscosities in pre and post Td5 LT230s Perhaps that extra 0.001mpg? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
4th Jan 2024 2:18pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5849 |
Ashcrofts suggest a EP80/90 oil. I did ask if a GL4 or GL5 spec and the answer was EP80/90. 1999 Defender TD5 110
4th Jan 2024 2:26pm |
You can get EP80W-90 in GL4 or GL5 flavors. All depends on the concentration of sulfur content. GL5 has about the double of such EP additives. Puma 110" SW
4th Jan 2024 2:31pm |
I did spot GL4 and GL5 spec. I think it will be GL4 for transfer case and GL5 for the front diff. 1999 Defender TD5 110
4th Jan 2024 2:36pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2641 |
Sorry for the late reply,
Gearshifts are a lot smoother for me, my gearbox is only about 25 - 30k miles with a short shift and bowler gearstick and it's a nicer experience shifting now. Diffs with the winchester ATB setup i had, previously there was some noise but since making the change it's a lot more silent. |
4th Jan 2024 6:18pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3643 |
Dave from Ashcrofts told me this was OK for his ATBs in defender axles
"Castrol Axle EPX 80W-90 Mineral Car Gearbox Oil GL5" so that is what I have been using with no issues DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
4th Jan 2024 9:01pm |
It turned out the published specs from the reseller are wrong.
I can post the specs sheet if it is allowed by the forum. Puma 110" SW ............................................................. Earth first. Other planets later |
5th Jan 2024 12:30pm |
In the end I went for Comma GL4 and GL5 oils. Cheers for assistance one and all. 1999 Defender TD5 110
6th Jan 2024 7:06pm |
