Home > Puma (Tdci) > Engine out - wiring ?
tankpeople
Hi - I'm in the process of removing the engine in my 2009 Puma 2.4 to change the chassis, and stuck with disconnecting the engine loom - I'm unsure how much needs to be removed/disconnected. I have checked all the connectors on the loom from the ECU via the injectors etc down to the alternator - all the connectors undo easily except the alternator main cables at the end of the engine loom which look very hard to get at . It looks like it might be possible to leave the main loom on the engine and disconnect at the ECU end where the other end of the loom seems to head into the cab via the bulkhead .
Any advice greatly appreciated.
Thanks in advance .
Post #1019848 2nd Jan 2024 2:59pm
NickMc
There is plugs at the bulkhead beside the expansion tank.
Post #1019858 2nd Jan 2024 3:45pm
As above, leave the engine harness on the engine and disconnect at the ECU connector and starter motor.
Whilst the engine is out, it is sensible to check the engine harness for chafing damage - it is very common for there to be significant damage at any point where the harness is secured to the engine.
Post #1019871 2nd Jan 2024 4:49pm
tankpeople
Thanks, does the large cable have a plug into the ECU module that comes out ?.
Post #1019872 2nd Jan 2024 4:51pm
No, IIRC it connects to the starter en route to the battery.
Post #1019898 2nd Jan 2024 8:56pm
tankpeople
Ok thanks for the help, Ill have a go tomorrow. Cheers JIM
Post #1019908 2nd Jan 2024 10:32pm
NickMc
There is a Defender electrical manual you can download from a search engine that you would probably find useful as it shows the connectors, pictures and locations.
Post #1019913 2nd Jan 2024 10:55pm
You may also want to download the WSM for the vehicle, since this outlines step-by-step the engine removal procedure!
Post #1019919 2nd Jan 2024 11:49pm
