Home > Maintenance & Modifications > Diff/Transfer case oil - EP80/90 GL4 or GL5
excossack
Having a front ATB and a centre ATB Ashcrofts/Winchester Gears suggest EP80/90 Mineral oil.
But, GL4 or GL5 ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1019700 31st Dec 2023 12:56pm
MK
Defenetly GL-5.
I use mineral oil for the front ATB and synthetic for the transfer case (with ATB) as it does not degrade that fast due to high temperatures (at least where I use it). Puma 110" SW
Post #1019705 31st Dec 2023 2:13pm
johnlad
Gl5 not recommend for any parts that contain yellow metals (brass).
I’d check with the manufacturer what they recommend.
Post #1019710 31st Dec 2023 3:24pm
MK
On a Std LT230 with "yellow" thrust washers I use GL-4. Puma 110" SW
Post #1019711 31st Dec 2023 3:34pm
excossack
Copied from another thread/topic
Gearbox:
R380: MTF94 or TRIPPLE QX ATF Dexron III
LT77: ATF Dexron II/III
MT82: 75W/90 fully synthetic MTF
LT85 (Santana): 20/50 engine oil
ZF autobox: ATF Dexron II/III
Jatco autobox: Texaco 402 oil or Dexron II if not available
Transfer Box:
LT230:
-- Pre Td5: EP80/90
-- Td5 on: 75W/90
LT230 with ATB: EP 80/90 mineral oil, not synthetic
Borg Warner: ATF Dexron II/III
Differential:
Standard: EP80/90
With ATB: EP80/90 mineral oil, not synthetic 1999 Defender TD5 110
Regards
John M0VAZ
Post #1019712 31st Dec 2023 3:40pm
MK
Differential bias effect on the central (ATB) diff on the transfer case is negligible, so synthetic GL5 is good for me. Puma 110" SW
Post #1019713 31st Dec 2023 3:51pm
bankz5152
Gearbox:
Transfer Box:
LT230:
-- Pre Td5: EP80/90
-- Td5 on: 75W/90
Differential:
Standard: EP80/90
Funny how they say pre and post td5 even tho they at both lt230s...
Ive always used GL4 EP90 Mineral in diffs and Lt230. Probably the last 50k miles or more. As suggested by Nige at Xcess4x4.
Or if you have expensive diffs then use swepco. Cant comment on diffs but it does make the R380 smoother.
Post #1019716 31st Dec 2023 5:17pm
MK
I would not use GL4 in a (hypoid) diff. Puma 110" SW
Post #1019721 31st Dec 2023 6:17pm
Dinnu
I believe that the Rover differential is a spiral bevel gear.
Not so familiar with Salisbury, but by the external look of the pinion flange, that looks hypoid. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1019732 31st Dec 2023 7:49pm
MK
There is a bit of an offset from the center. AFAIK
Anyway, synthetic gear oil lasts longer on the lt230 subjected to high temperatures. Puma 110" SW
Post #1019776 1st Jan 2024 2:05pm
excossack
bankz5152 wrote:
Gearbox:
Transfer Box:
LT230:
-- Pre Td5: EP80/90
-- Td5 on: 75W/90
Differential:
Standard: EP80/90
Just an ATB up front and ATB in the transfer case. Wincheser also suggested SwepCo.
A decent EP80/90 mineral as suggested by Winchester/Ashcrofts should do the job. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1019782 1st Jan 2024 3:41pm
Likeomg
Went with Swepco, made a bigger difference than i would of thought
ATB in diffs from winchester
MT82
Swep-Co 202
Approx 2.2Ltrs Needed
2.5Ltrs Sold
Swep-Co 201
LT230 - 2.3Ltrs Approx
Front Differential - 1.7 Ltrs Approx
Rear Differential - 1.7 Ltrs Approx
5.7Ltrs Needed
6Ltrs Sold
Post #1019812 2nd Jan 2024 1:36am
Mo Murphy
Likeomg, what difference did it make, for it to be so noticable ?
50 Shades of Pennine Grey
Post #1019815 2nd Jan 2024 6:11am
Agree,
GL4 in transfer box, GL5 in diffs. WeWillWin🇬🇧🇺🇸
Post #1019879 2nd Jan 2024 6:41pm
excossack
According to Swepco, Swepco201 does have a GL-5 Specification. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1020061 4th Jan 2024 9:20am
