Home > My Defender > Defender 90 puma low milage but was used on a farm.
Page 3 of 4 <1234>
Landy addict
Thanks for the complement NickMc if we lived closer together I would have no problem helping with a project but I'm sure anyone could do it if they had the tools. I am lucky I have been building up a tool collection for many years.
Post #1006236 2nd Sep 2023 7:08am
Landy addict
Thought it was time for an update not had as much chance to work on it as I would like as been working away most the time this year.
Some new parts 2x swivel ball kits & brake callipers to allow vented disks.
made a start on painting some parts
made a start on the axles
Aframe
rear axle on & brake lines made up
Post #1019696 31st Dec 2023 10:38am
Screbble
Looks marvellous- better than new 👍
Post #1019704 31st Dec 2023 12:29pm
Co1
Great work Thumbs Up
Post #1019706 31st Dec 2023 1:18pm
Landy addict
split the engine & gearbox to check the clutch glad I did as one of the springs had fallen out.
new Clutch kit from LOF
engine & box in
front & rear anti rollbar
Post #1019763 1st Jan 2024 9:55am
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
wicked stuff Thumbs Up
I have alives comfort springs but with fox shocks, theyre lovely. 4.0 V8 Defender 90
My Instagram
Post #1019784 1st Jan 2024 4:18pm
Great work, lovely workshop!
Post #1019787 1st Jan 2024 5:39pm
Re: Defender 90 puma low milage but was used on a farm.
I’ve just caught up with this thread, very nice build and I love the attention to detail.
It’s great to know almost every nut and bolt as you go through each section with an eye for detail.
Landy addict wrote:
I cannot understand why LR dual skinned this area, when I was looking at mine a couple of years ago I noticed it, I would have thought it would have made sense to either use thicker plate, or box section with drainage if for captive wiring but a semi sealed dual skinned set up seems just like a corrosion trap for little reason to me.
Landy addict wrote:
Then 2x coats epoxy chassis black
Looks excellent. Thumbs Up
Landy addict wrote:
Finished bulkhead.
Excellent again, surprised the corrosion was so bad in very specific places on it looking at it, but, very good in others. Evidently rust trap areas, probably best all of us keep an eye on. Laughing
Landy addict wrote:
Aframe
Really nice, I have the same on mine, something else to stick a grease gun on is always useful. Mr. Green
Very Happy
Oh yes, been there done that before. Just out of interest was it a LR Gen clutch or perhaps you aren’t sure? Mine was just the same last year and it was a LR offering…
My 90 has the Sachs Transit 4x4 clutch in now, I’ve very happy with it. This one I have and the LOF offering seems two leading offerings. LR’s offering I have my doubts about, so much so I didn’t
feel like having another put in.
Landy addict wrote:
I think that the ARB lower link to ARB Stabiliser bar bolt is in the wrong way around, it looks a little on a skew, I could be wrong but I think the bolt goes through the ARB eye and the nut is on the link side.
As I said I could be wrong but the WSM probably shows the orientation, if I’m wrong, I may well be but the bolt being placed through the ARB, and the nut on the link side I think means it sits a bit better I think. Happy to be corrected though if I am wrong. Very Happy
Plus the ARB eye tends to move / pivot more than the link. Nuts towards the centre of the axle, then the ARB eye pivots just behind the washer and neck of the bolt head just beyond the washer, on the shank of the unthreaded part of the bolt.
Keep us posted on your build if you can, coming on really nicely so far, keep up the good work. Thumbs Up
It must be so nice to have the workshop in peace and quiet too, without interference from others I.e. neighbours or limited room etc too. Thumbs Up Play Stupid Games, Win Stupid Prizes.
Big Brother is Watching.
Post #1019791 1st Jan 2024 7:05pm
Dinnu
Great work. Great progress too.
I do not think that area is double skinned. However the aluminum is sandwiched between the seat belt anchor going to the chassis outrigger and the seat belt reel bracket. I had ordered a new pair of genuine brackets that go between the tub and the chassis outrigger, and surprise surprise, they were just bare steel, no coating whatsoever. No wonder they rust and cause the galvanic corrosion as seen here. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1019799 1st Jan 2024 8:51pm
NickMc
The other vehicles in it aren’t bad either Bow down
Post #1019801 1st Jan 2024 9:01pm
Landy addict
Landy addict wrote:
Finished bulkhead.
Landy addict wrote:
Aframe
Very Happy
Thanks for the comments Steve as for the ARB I think it is the right way round going by the diagram below the bolt might be skew as it isn’t tight, I left them all slack just in case I needed to remove it.
If anyone ells is reading this that knows the correct way can you please comment.
It was original LR clutch
Double skin on the bulkhead footwell I was thinking of drilling a small hole into the cavity & spray some Lanogaurd then put in some grommets to seal it off again.
Post #1019808 1st Jan 2024 10:00pm
Landy addict
Thanks for the comments Dinnu, you are correct this is not a double skin area I think the reference was to the bulkhead footwell. I have ordered some replacement anchor points that are galvanised I will coat them with several coats of epoxy just to be safe.
Post #1019809 1st Jan 2024 10:13pm
Landy addict
I was going to go for the Fox shocks but thought they might be too soft for me I was told these new Alive shocks developed with Bilstien to give an in-between hardness so thought I would give them a chance.
Post #1019810 1st Jan 2024 10:17pm
Landy Addict - Ah that explains it, I’ll have a look at mine tomorrow. I know they do sit skew wiff when not tightened up when I’ve had mine off before.
I know mine were bolted on the same way they were from the factory and I mirrored that when I have had to take them on and off.
I might just be thinking it, the WSM is usually right, only it has been known that the WSM can have anomaly’s in it and some errors though rare there is the odd spec in it that has been found to be incorrect.
I would lean to believe the WSM is correct now, seeing as you mentioned they weren’t tightened up and probably mine are the same way as yours are fitted and the WSM.
It’s been known for the links to be accidentally fitted upwards too, easily done for sure.
In some cases, it’s the poor diagram sketches or descriptions, there is a few mis matched torque settings too in there I believe.
Damper washer orientation can be a troublesome one as well. Razz
With the double skin bulkhead parts, I thought about spraying rust proofing in there too but when I had it and the application straw I seem to remember it was difficult to get in there as the gap between the two was so small and obstructed in many places.
I think there was small rubber bungs in places, similar to wiring blank grommets that are painted over.
Which gives a bit of access, but, it’s very difficult to do a good job of rust proofing in there.
Could it not be filled with a liquid rustproofing solution rather than aerosol spray?
Not so good regards leakage down onto the floor though if it did.
Very Happy Play Stupid Games, Win Stupid Prizes.
Post #1019811 1st Jan 2024 10:58pm
NickMc
3M do a good Creeping cavity wax if you want to try something between the panels.
Post #1019813 2nd Jan 2024 1:40am
Page 3 of 4 <1234>
