Home > Puma (Tdci) > Water Ingress / gap filler |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 553 |
Hi.. If you are looking for a strong permanent seam sealer then the body shops sell pu adhesive fillers for the job..there are many brands available and a wide price band I've found.. The technical specs may vary slightly but my experience using the stuff is that any pu adhesive does the job
It is flexible to a point but once sets can pretty well only be removed mechanically.. If you are looking for a softer flexible sealer that does not really set but gives a waterproof seal but allows separation, then they are usually butadiene based and also sold in tape form.. Which can give a neater job.. But personally I prefer the cartridges.. |
31st Dec 2023 12:27pm |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 571 |
I found this stuff does a good job of filling those gaps.
https://www.woolies-trim.co.uk/p-1979-body-caulking-10-strips |
2nd Jan 2024 4:13pm |
