![]() | Home > Tdi > Brake Overhaul |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 923 ![]() ![]() ![]() |
IMO if you want something a step up from the OE mintex / ferrodo then I'd always say EBC ultimax
Once bedded in I've found them to be a good pad that stops well. I did a complete brake job on mine a few months back and used EBC pads and discs and now they have bedded in the performance is great and i'd reckon better than factory standard. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 519 ![]() ![]() ![]() |
I've used ebc before on other vehicles with no problems, but had to take them off my 110 as they didn't work when cold. I've put in mintex which are much better and perform normally. It could be that the ebc aren't not suitable for the discs I have, perhaps.
cechurap Member Since: 22 Aug 2020 Location: Prague Posts: 8 ![]() ![]() ![]() |
I had EBC green stuff on the rear of my 110 and they definitely don't work together with Delphi discs.. they were squeaking horribly
