Home > Puma (Tdci) > Help diagnosing intermittent random engine cut-out
Page 3 of 3 <123
Stacey007
^ Correct
I was hopefully if I could re create it we can find the fault.... Changing the main relay seemed to work for a couple of weeks but then its back...
Post #654351 2nd Oct 2017 2:36pm
MMMC
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Alpine White
Hi - Has anyone been able to sort this problem out? My car has been in the auto electrician all week and he still can't find the issue. Help would be much appreciated. Cheers Marcus
Post #809676 10th Jan 2020 1:53pm
Stacey007
Hello
Sorry I thought I had updated this post
Mine has 'touch wood' vbeen sorted now since changing the rear part of the ignitian barrel.
All have worked perfectly, it must have been an iffy contact evey now & again just failing then coming back on.
Cheap fix in the end and piece of mind restored Smile
Hope your s is similar fix
Post #809677 10th Jan 2020 2:00pm
X4SKP
Reading the various threads on Intermittent Starting / Cut Out problems
If I was faced with this (again) I would 100% swap out the ignition switch,
just to take it out of the equation mine was intermittently not starting...
it never cut out when running but it looks as though some do.
The Ignition Switch is cheap to buy (probably part of the problem) and depending
on what your set up is can be a Censored to replace...not difficult just involved
Here's my fix 2 years later all OK and (I carry a spare just in case)
https://www.defender2.net/forum/topic56773...p;start=45 SKIP
Post #809679 10th Jan 2020 2:16pm
MMMC
Thanks to both of you for your help. I have just spoken to my auto electrician and he is ordering a new ignition switch. I'll update when I know more.
Post #809681 10th Jan 2020 2:37pm
X4SKP
Post #809682 10th Jan 2020 2:43pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
My problem went away when I started using better fuel - see this thread https://www.defender2.net/forum/topic69868.html
I mainly do short journeys, and I suspect sensors were getting mucky between longer runs.
Post #809686 10th Jan 2020 4:07pm
MMMC
That certainly is interesting. I've been using Morrisons fuel for quite a long period of time and also Jet. I will make the change! Cheers
Post #809688 10th Jan 2020 4:23pm
dannyragsdale
Papau New Guinea 2012 Defender 110 Puma 2.2 HT Fuji White
Looks like I am joining the group of intermittent cutouts. Going to be checking all the things listed, but did the ignition barrel fix things for you too, MMMC?
Post #1019229 25th Dec 2023 9:17am
Page 3 of 3 <123
