![]() | Home > Maintenance & Modifications > TDCI Crank oil seal tool |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
Assuming that you mean 303-682, the tool for aligning the timing cover on the front of the engine, then the genuine part from BOSCH Global (the JLR official tool supplier) is listed at £22.49 per unit (plus VAT and shipping). The snag is that you need an account to buy from them.
I really cannot explain why the aftermarket suppliers are charging £90 plus for a replica - it does seem rather extortionate. You could give Dingocroft in High Wycombe a call, they usually list LR special tools at only around 100% mark-up but don't list this one on thier website. |
neirbossor Member Since: 10 Jun 2021 Location: Aberdeenshire Posts: 23 ![]() ![]() ![]() |
Thanks, I have found some unofficial ones on ebay for around £55 but still a wedge of cash for a piece of turned nylon and steel. The markup on those things are incredible...low volume product I suppose.
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 219 ![]() ![]() ![]() |
Making your own doesn't require any special workshop tools. Just a scrap piece of wood and a few bolts.
Give it a go, you can't go far wrong. ![]() Click image to enlarge ![]() Click image to enlarge |
haha superb!
That will obviate the need for 303-679 (the remover/installer tool) but doesn't help with the need for 303-692, the aligner for the cover.
It is again frustrating that the former is a mere £19.65 (+VAT etc) from Bosch, but around £90 from anywhere else. |
If you’re only changing the oil seal then you don’t need the special alignment tool as that is only required if you’re installing the timing cover. A new crank seal will come with its own disposable alignment sleeve which protects the seal lip as you slide it over the end of the crankshaft.
