![]() | Home > Puma (Tdci) > Steering |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3520 ![]() ![]() ![]() |
You could remove the current damper, and drive and test the Defender and see if it makes a difference. If it does not, then most likely, a standard steering damper will not make a difference either. If the rest of the steering system (swivels, ball joints, box itself) are in good condition, the damper is not really needed.
Have you driven any other Defender to compare? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Naycrx Member Since: 11 Oct 2023 Location: Nottinghamshire Posts: 147 ![]() ![]() |
Only our Series 2 LandRover - Obviously not comparable- ok thanks for your help
