Home > Maintenance & Modifications > Galvanised or not
nutty
Galvanised or not
I have to buy a new rear corner for my Defender after a small accident and see that there is an option to buy a galvanised part and not galvanised.
Will buying the galvanised part prevent corrosion ?
The rear corner post started corroding almost immediately after a paint job and I hadn't gotten around to have it fixed but now I have to and am wondering if I should go for galvanised or not ?
Post #1017970 10th Dec 2023 11:48am
Dinnu
GALVANIZED GALVANIZED GALVANIZED.
Just ensure that is prepared correctly before painting. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1017973 10th Dec 2023 11:54am
donmacn
In my experience buying the galvanised part will definitely stave off corrosion. I replaced the rear corner strips on my car in about 2008. At that time the car was already 14 years old.
The galvanised corners are still on the car and show no external corrosion at all. I recently had one of them off to do a bit of straightening (don’t ask!) and there’s mild corrosion on the inner faces but not so much that I had any worries about putting it back on. Bear in mind also that this car is used all year round in the Scottish Highlands. I know it’ll be a lot colder where you are, but in our ‘in between’ temperatures we love to slather the roads in salt.
So yeah, for my money go for galved. In fact that’s something I’ve done on my car at every opportunity - galved chassis, bulkhead, capping, doors etc.
Interested to hear what other views might be.
Looked at from the opposite perspective, what’s the down side? A little bit more prep before painting? A little bit more expensive? I think the benefits outweighs any disadvantages. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #1017974 10th Dec 2023 11:58am
paul 123
United Kingdom 1995 Defender 90 300 Tdi HT Auto Rutland Red
any thing thats galvanized will last longer so thats the way to go. i have used all galvanized cappings on my 90 rebuild along with chassis and bulkhead.
Post #1017976 10th Dec 2023 12:23pm
Screbble
I cannot see any downside.
The quality of galvanising can vary considerably.
Preparing adequately before painting is key.
Post #1017980 10th Dec 2023 1:31pm
nutty
thanks
thanks a lot for your answers, definately going for galvanized Smile
Post #1018025 11th Dec 2023 7:33am
Dinnu
Re: Galvanised or not
Just sharing my experience... I bought aftermarket ones, and found that the rivet holes did not align well, and was reluctant to drill new holes in the tub. So I preferred to repair the damaged corner, and send that for galvanizing.
Post 2012 corners have different rivet hole pattern (more rivet holes). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1018060 11th Dec 2023 3:18pm
