Home > Tdi > Grease nipple for water pump
LHolden
United States
Just bought a Proline replacement water pump for my 200tdi. Is this small hole for a grease nipple or just a drain hole?
Post #1017927 9th Dec 2023 8:15pm
Dinnu
Usually there is a drain hole, so that if the seal leaks, the bearing does not fail.
But from your picture in the gallery, looks like hole is on the side? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1017931 9th Dec 2023 9:12pm
LHolden
United States
Thanks for your quick reply. This hole is definitely beneath when it’s installed which makes it an odd place for a nipple fitting.
Post #1017933 9th Dec 2023 9:39pm
Retroanaconda
That’s because it’s not one, it’s a drain hole as above. When water leaks out, you know the pump is failing.
Post #1017943 9th Dec 2023 10:44pm
LHolden
United States
Thumbs Up
Post #1017952 10th Dec 2023 1:46am
