Home > Maintenance & Modifications > Winch Question/opinions
Surrey Rover
Forgetting the cost and if you needed it or not, if you had the opportunity to fit one of the following winches to your truck would you go for either:
A Warn 8274 or
A Red Terrier Hydraulic Winch which is PTO driven
The winch in question will be used for self recovery and winching tree butts and probably anything else that could be winched, just because...
both have pro's and con's as I see it, so it's a split decision Nick
2.2 110 Tipper
Post #101577 22nd Nov 2011 11:07am
8274 Thumbs Up
Post #101595 22nd Nov 2011 12:02pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
I've always had a Warn HS9500i ... Very good!
But I have two friends that have/had 8274 for over 10 yrs and they're great ... never broke down! they're serviced regualrly and work fine ...
about the hidraulic one never tried Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #101607 22nd Nov 2011 12:21pm
BigMike
given the choice, the hydraulic.
Post #101613 22nd Nov 2011 12:43pm
TJ101
If its for work,, trees etc,, i would say hydraulic , will just pull all day, look at Mile Marker, or Red Winch
Have 4 or 5, 8274's from bog std, to twin overvolted motors ones, great winch for competition !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #101665 22nd Nov 2011 3:02pm
BigRuss
Well if you have a hydraulic winch you need drive and space to put it! (resivor etc)
Electric is more compact and can run without drive!
As you say both are good in different ways. Will the hydraulic work if you tair a line? Will the electric work is some one nicks the motor? Russell
2011MY 110 XS USW Black
Post #101667 22nd Nov 2011 3:13pm
Romadog
Hydraulic all the way.
Why would you tear a line?
Anymore than if you tore a power cable??
If not hydraulic then pto mechanical winch is just the dogs danglies
Post #101763 22nd Nov 2011 9:34pm
jst
hydraulic for commercial ie tree pulling
8274 for competition as its versatile ans spares are easy to come by
tds for anything else. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #101781 22nd Nov 2011 10:17pm
