![]() | Home > General & Technical (L663) > Bonnet release mechanism |
Pop around the front and give the top of the bonnet a good sharp push down then re-try the mechanism. I suspect it is pretty chilly up with you and things can get stiff in the cold.
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1429 ![]() ![]() ![]() |
Yes mine was like this, it started off with just it failing to open on one or two occasions but steadily got worse. I asked them to have a look when it was in for service and they said they adjusted the mechanism and lubricated it and it has been fine ever since
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
lac Member Since: 29 Jan 2023 Location: Moray Posts: 38 ![]() ![]() |
Cheers guys.
Hairy Dan sounds like you had the same issue as I’m experiencing. Annoyingly the car was just in at the dealers for the 2 software updates and it was the day after I tried to open it when it failed. Hopefully the washer level light will stay off till I can get into the dealers 110 D300 XD HSE, Carpathian, Tow pack. Air Susp pack, cold pack, hud, |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 292 ![]() ![]() |
Mine did this too. Get someone to hold the lever up fully, or wedge it up, while you give a sharp press down on the front of the bonnet. That worked for me until the first service when they tried adjusting the cable but that only worked for a short time. In the meantime they'd ordered a new cable, which was on back order of course, but once fitted has fixed the problem so far.
Cheers for the tip geobloke and Nuclear Nick. Has been a bit icy up here but think it’s more needing adjusting or replaced. Will get the wife to try as I’m away till January now. Baa humbug! 110 D300 XD HSE, Carpathian, Tow pack. Air Susp pack, cold pack, hud,
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1227 ![]() ![]() |
just checked mine, popped open nicely.
Only downside was as I lifted the bonnet, water trickled out between the two skids and dribbled water over the plastic engine cover. In total about an egg cup full. I am hoping this is heavy condensation built up over the couple of days I have not used the car. ?? |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2708 ![]() ![]() |
Cables stretch - it’s a known fault.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2967 ![]() ![]() |
Old habits die hard
As a previous owner of old Defenders l greased all these mechanisms when l got the new one. They were all dry, as in, no oil or grease on them. The bonnet/hood release on mine works beautifully. To get to the catches properly you need to remove the cover from the front of the engine bay but it doesn't take more than a few minutes. |
Yes they can, but I’ve never had this fault with any other car, and this happened to my Defender only a couple of months after delivery. And strangely, adjustment made little or no difference so replacement seemed to be the only option on a car less than a year old having had the bonnet opened only a few times. |
I did this too when the car was new but the cable still stretched and had to be replaced. |
As I said, it’s a known fault. The cables are cheap rubbish quality and stretch, once adjusted they soon stretch more and will eventually snap. It’s been a known problem on Land Rovers for years. |
