Home > My Defender > What Did You Do In Your Defender Today |
Click image to enlarge |
2nd Dec 2023 4:02pm |
PoormansXS Member Since: 21 Oct 2023 Location: Lincolnshire Posts: 55 |
Smart using one that’s only on when the engine is running rather than when the ignition is just switched on. I used the exmoor kit, mud do some nice original style switches at a fraction of the cost which I fitted in mine for a more OEM look. The downside having done it this way is that without fitting the high low switches somewhere else, it’s on high all the time! Although I don’t mind that I’m either cold enough to use it or I’m not! I also picked up and fitted a loom for a heated screen from mobilecentre cheap on Facebook. I can not tell you how good that is. £300 for fitting of a heated front screen is abit pricey but it’s worth every penny for defrosting and demisting. I’ve also got the little demister vents from foundry 4x4 which by the way are great because they direct some hot air at the side windows so you can actually see the mirrors! |
2nd Dec 2023 6:57pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17520 |
Not strictly today but yesterday, passed another MoT test.
One small repair needed to pass, first attempt failed with a reported split rubber boot on the drag link ball joint at the steering box end (I have a Gwyn Lewis HD Disco-style conversion). I was surprised at this since the drag link is only a year or two old, but if there was to be a fault that is an easy fix. So drove home, popped the balljoint apart and found that actually the boot was in perfect condition, it had just for some reason slipped out from under the retaining spring clip. So a quick clean up, regrease, reassembly, and I was good for the retest within 35 minutes of leaving with the "deferred success" certificate including 10 minutes driving time and the time it took to get the tools out and put them away, all at zero cost for the repair. Not bad for a 16-year-old vehicle with 270,000 miles on the clock! |
2nd Dec 2023 8:16pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5873 |
Well. The update I have is, this morning the heater fired up first go and got the car nice and warm before my early dart. Hopefully all sorted. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
3rd Dec 2023 4:14pm |
I should really get around to fitting one of these heaters. Just always throw on an extra layer |
3rd Dec 2023 4:25pm |
Waka56 Member Since: 08 Nov 2023 Location: Hamburg Posts: 166 |
Changed injectors seals and rock cover gasket. Making my Defender great again. (Or trying to at least xD)
4th Dec 2023 10:24pm |
pistonfields Member Since: 29 Mar 2022 Location: Zurich Posts: 75 |
Finally fitted a winch.
5th Dec 2023 12:20pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1105 |
Is that even allowed in Switzerland?
5th Dec 2023 12:35pm |
The heater works well and worked well this morning as well. Frosty screen before breakfast, no frosted screen by the time I left for work 20mins later 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
6th Dec 2023 9:36am |
Nobody likes a show off
6th Dec 2023 10:11am |
hahaha 1999 Defender TD5 110
6th Dec 2023 10:45am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
Got the sub relocated from the cubby box to the rear door, it now thumps properly!
Click image to enlarge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
14th Dec 2023 6:50pm |
Broke out the jet hose and knocked off the worst of the mud from both the vehicles. I have seen pigs livin' in &*%$ that are cleaner
15th Dec 2023 8:13am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20559 |
Mine was due around the same time as yours BW - to my surprise mine was a clean sweep with nothing at all on it. With steps just advised last time (corrosion as usual..). A quick and cost free fix is always good! Mines on 96k so quite a bit to go yet to get to your mileage, though she’s going to need a service imminently so plenty to be getting on with. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
18th Dec 2023 6:05pm |
