![]() | Home > Tdi > what radiator for 300tdi? |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 208 ![]() ![]() ![]() |
So the Nissens one is basically identical to the stock images. It feels unnervingly light. I've changed to constant tensions clamps because the hose stubs are now plastic and the screw hose clips have the potential of cracking the if done too tight. As I found out when tightening the plastic top bung which cracked in half! Will replace with a brass one. Another major risk is snapping the smaller bleed spigot whilst tightening the upper oil cooler hose with a spanner. One of the top mounting studs doesn't reach all the way through the frame for some reason
In all, I'm only mildly satisfied, but have had to act quickly. The only saving grace I think is that the aluminium might be more corrosion resistant than the copper/brass? I'll keep ahold of the used one for future recore options. As you can see, it's gone from some fins missing to this in one year: ![]() Click image to enlarge LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
My local Radiator shop, which has been going for a long time told me unfortunately Nissens are no longer the quality they once were either
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5260 ![]() ![]() |
my dad went to the local rad place, and got an Alu one, and he has no trouble at all.
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
PAT303 Member Since: 25 Feb 2013 Location: Australia Posts: 125 ![]() ![]() ![]() |
The Nissens one in my defender has withstood everything the Australian outback has thrown at it |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 837 ![]() ![]() ![]() |
Can I just say....?
When I got my 94 tdi nearly 10 yrs ago the rad was looking pretty tired (probably original?) When it failed (shortly after I put fresh antifreeze in) I did some deliberation about the recore/brass core OEM/ali options and in the end plumped for the cheap Paddocks rad as it was well, ...... cheap. TBH, swapping out a rad is a very, very simple job and the rad failure mode is usually to give plenty of warning (if you watch these kind of things) like damp patches, falling coolant level, puddles under a parked vehicle etc. If a rad only lasts 5-10 yrs instead of 20+ yrs what is the major hardship? If you are on top of your Defender maintenance/check regime as you should be then a leaky rad should be spotted and addressed long before it becomes an issue. |
