Home > Technical > Non-return valve front washer
Learningasigo
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Corris Grey
During some light winter maintenance I tried to unblock my front washer jets. A needle didn’t help and in fact only made it worse. I used some compressed air (dust/air in a can) and sprayed directly into the nozzle. This worked an absolute treat and cleared both with easy using only a few seconds of air. Both worked fine for a short while….
I remember recalling the sound of air escaping in the bonnet during the clearing but assumed it was a straight feed to the pump and was probably some sort of expansion valve.
The system is now best described as ‘limp’. I haven’t seen any wager fluid leaking underneath, nor is the washer bottle empty. I wonder if I have blown the non-return valve.
Does anyone know where the non return valve is, is it easy to see and access? It is 110 2.2 puma with air con. I have attached the schematic for the washer system.
Thanks for any advice or possible areas to check for damage.
Post #1016939 1st Dec 2023 6:39am
Learningasigo
Re-posted on the Puma 2.2 section. No idea how to delete this!
Post #1016942 1st Dec 2023 6:57am
Screbble
Although not Puma, mine is down by the side of the heater box, close to the bulkhead, under the bonnet on the near side. There was sufficient ‘give’ in the pipe to carefully pull out it to work on it.
Replacing mine was transformational - night and day - but others remove them completely.
Good luck 👍
Post #1016943 1st Dec 2023 6:58am
Learningasigo
Thanks Screbble. I will have look later today and let you know how I get on!
Only 2 weeks into Defender ownership so this should be a gentle introduction to self help maintenance 😂
Post #1016945 1st Dec 2023 7:11am
Screbble
It’s all good fun as ‘they’ say.
As you will see from the photo, they are only small so have a ‘feel’ along the pipe first and you should find it.
It’ll be literally tight in the corner, in the gap between the heater box and inner wing.
Good luck 👍
Post #1016947 1st Dec 2023 7:23am
Learningasigo
Found it! Very easy spot in the 2.2. But still in the same space with a little more room. Took out the valve, cleaned it and rebuilt it - small amount of crud. It was actually a blockage that I had pushed further down into the pipes. So a bit more air, focused from the valve end in the right direction this time, worked a treat.
Post #1016968 1st Dec 2023 10:40am
Screbble
Thumbs Up Thumbs Up
Post #1017037 1st Dec 2023 2:54pm
Screbble
Mmmm just had one of my ‘new’ NRV’s come apart resulting in what looks like an ectoplasm exposure.
Quick fix but flipping annoying ☹️
Post #1019177 24th Dec 2023 11:00am
Tartanterror
England 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Did you need to remove anything to locate/replace it?
Post #1050805 5th Nov 2024 1:54pm
Tartanterror
It’s ok - did more searching and found it
Post #1050812 5th Nov 2024 3:28pm
Screbble
No just ‘feel’ for the pipe adjacent to the heater box and you will find it 👍
Post #1050813 5th Nov 2024 3:35pm
Tartanterror
Thumbs Up
Post #1050814 5th Nov 2024 3:39pm
