Home > Tdi > Glow plug warning light timing
driver
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
The glow plug warning light seems to be taking a long time to go out, up to 30 seconds is this normal? or is this a sign the glow plug timer/relay is on its way out, its a 300tdi.
any advice appreciated
Post #1016650 28th Nov 2023 8:38pm
Ihod
United Kingdom 1998 Defender 90 300 Tdi ST Rioja Red
I’d say it’s a sticking relay or a short in the glow plug wiring or a plug causing the issue.
Start with the first as it’s easier to determine (and cheaper to replace).
Tbh I tend not to cycle the pre-heat unless there’s a frost or the van has been unused for some time (and haven't had an issue with that).
If you go start thro’ the heat position on the ignition does it come on and stay on?
Either way if it’s staying on it may cause issues with the loom or plugs in the end. Ian
MY1998 300Tdi 90 Hard Top (Now Soft Top)
MY2015 110 XS SW - Sold
MY2008 110 County USW - Sold
MY1962 Series IIa Truck Cab - Sold
MY1994 300Tdi 90 Hard Top - Sold
MY2001 TD5 90 Truck Cab - Sold
Post #1016681 29th Nov 2023 7:08am
landy andy
30 seconds doesn’t sound like an excessively long time if it’s cold.
Post #1016684 29th Nov 2023 7:51am
mini Anaconda
30 seconds sounds like a long time.
I don't have a timer on my 200tdi glow plugs but I hold the key for 5-10 seconds and it always starts at the touch of the key. BORG - Bucks & Oxon 4x4 Response Group
Post #1016686 29th Nov 2023 8:40am
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
I spent two years pre-heating my 200 TDI, only to discover that the glow plugs weren't connected, not even a wire! I guess they are not essential!
Post #1016688 29th Nov 2023 8:48am
driver
Resolved by fitting a new glow plug timer, everything back to normal now.
Post #1017775 8th Dec 2023 9:39am
