Home > General & Technical (L663) > Lights operation |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1202 |
I have front DRLs ...... and REAR DRLs whist driving. The rear DRLs are only the small twin lamps, but better than none at all.
This was a major mod I did a few months ago, a mod which involved cutting into the rear lamp clusters. Click image to enlarge the wire seen in the above photo is fed from a fused ignition live terminal in the rear fuse box. this suits my purpose. |
24th Nov 2023 4:50pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2921 |
That's a nice modification, good work. Much safer than no rear lights
24th Nov 2023 5:56pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2688 |
The easiest way to have your rear lights on during the day is just to turn the headlights on manually surely? Okay that puts the main headlights on as well but that’s not really an issue.
They won’t go off until you either turn them off, or put it back to auto. |
24th Nov 2023 6:55pm |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1432 |
That would be a great 'how to' if you ever fancy writing it up. Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
24th Nov 2023 8:22pm |
Yes l guess you are right, you can't have too much light if it makes you easier to see by other drivers. l just wondered if anything could be changed with GAP. |
24th Nov 2023 11:42pm |
Click image to enlarge This is what the rear lights look like whilst driving in daylight. At night all 4 (each side) are illuminated. I do now have the circuitry to turn off these lamps (red) when indicating (amber) and restore to DRLs. I hope to have this mod completed soon. |
25th Nov 2023 12:23pm |
