![]() | Home > Td5 > TD5 1999-2002 Throttle Pedal not responsive ECU Amber light |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5792 ![]() ![]() |
I’ve replaced the ecu to pedal a few times, and never had any issues just using trailer cable (so enough wires) and joined via cutting and soldering in place. So sorry never needed to find Header 0291
On your picture it shows wires on the top left. These have a number of 160 on the end. The 160 is their length in mm’s.
B=black 1.5=gauge of wire 160=length. So the header is only 160mm from ecu. |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1121 ![]() ![]() ![]() |
Cool did not know that! Thanks, now I just have to remember that next time I do wiring troubleshooting
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
I didn’t know that either - thanks for sharing ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6634 ![]() ![]() ![]() |
You've not bypassed the pedal wiring correctly. The loss of glow warning shows you've mixed up the Black/Yellow for glow plug warning light with the one you meant to use for the pedal. Easily done as LR used the same colours for multiple things on the Td5 ECU loom, and the pinout numbering isn't intuitive (it zig-zags).
This is the face (not wires side) of the connector. ![]() Click image to enlarge Headers just join wires together. So for the pedal, the white/purple from the ECU is split into two to go to the pedal. Looking at the full pedal wiring diagram for 1999-2001MY: ![]() Click image to enlarge You need these terminals: ![]() Click image to enlarge Remembering this is the non wire side. ![]() ![]() |
Benny Member Since: 03 Nov 2016 Location: Plymoth Posts: 15 ![]() ![]() ![]() |
Hi Martin
Thanks for the reply. So to be sure, to be sure as it were. Which actual wire goes to which pin on the ECU? Thanks in advance |
The wiring diagram snippet I posted gives you the 6 at the pedal end going to the 4 at the ECU end.
At ECU
WG. White and Green to pin 12 on ECU connector WS. White and Slate grey to pin 36 on ECU connector BY. Black and Yellow to pin 26 on ECU connector WP. White and Purple to pin 14 on ECU connector |
Landy Andy and Martin thanks for this. I'll have another go and get back with the outcome.
No problem. That is what this place is for.
![]() I’m learning too, I didn’t know about the wire length info, or the pin number info on the drawings till looking into this for you, so we are all learning. Apart from Martin as he’s the wiring god when it comes to this stuff. From what Martin is writing it sounds like you have just picked the wrong Black Yellow. Possibly you’ve used 30 ??? Keep us up to date on how it’s going. ![]() ![]() Last edited by landy andy on 22nd Nov 2023 9:01am. Edited 1 time in total |
Genius. I have always wondered what those numbers referred to ![]() |
Hi Landy Andy. Spot on! I selected wrong black yellow connection. Many thanks to yourself and Martin.
Regarding the symptoms I had regarding amber management light and no throttle response, only tickover. Is there anything else I could also check out? |
The symptoms for failed ecu-pedal in my experience has always been.
Start engine, everything ok, no warning lights, touch pedal, no increase in revs, warning light on. Or drive through puddle, zero throttle response, warning light on, restart then as above. Starts ok, till you touch pedal. You could check you crank sensor and it’s wiring, but think you are on correct track ![]() |
Thanks Andy. Hopefully all ok. Until next issue 🙂
