Home > My Defender > My puma 2008 |
Very pretty in white. Love a white and black Defender
20th Nov 2023 6:42pm |
Waka56 Member Since: 08 Nov 2023 Location: Hamburg Posts: 126 |
Yeah a bit of black will be done to, but that's not the priority Making my Defender great again. (Or trying to at least xD)
20th Nov 2023 8:55pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6560 |
The grey Bosch relay and the metal cased relay are non original. Evidence of overheated terminal on grey Bosch relay.
Some kind of bodgery going on with the wire stuffed into the black relay socket and feeding the fuse. There’s an additional 25A fuse in the right in a separate holder that is also non original. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
20th Nov 2023 9:07pm |
Yeah it looks dodgy, have to get a booklet about the fuses. Making my Defender great again. (Or trying to at least xD)
20th Nov 2023 9:12pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2066 |
That’s a really nice Defender 👍
Just looking at the fuse box photo, I agree with Martin’s observations. I haven’t got a Puma so can’t really tell for sure, but would you expect that lower steel frame in the fuse box photo to be so rusty? Is that a sign of previous water ingress? |
20th Nov 2023 10:08pm |
PS I know you’ll have a list of jobs to do, but you may want to look at your wiper wheelbox/spindles etc. in due course 👍
20th Nov 2023 10:11pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10661 |
Nice 110 you got there 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
20th Nov 2023 10:33pm |
Because of this wiper not always going all the way down right? Making my Defender great again. (Or trying to at least xD) |
20th Nov 2023 11:10pm |
Yes it looks as though both wipers are not aligned.
20th Nov 2023 11:11pm |
Looks like a fun job to do. I'll make sure to find out what else to change in the same time.
Making my Defender great again. (Or trying to at least xD) Last edited by Waka56 on 20th Nov 2023 11:20pm. Edited 1 time in total |
20th Nov 2023 11:18pm |
It appears to be a link between the output of the relay which then feeds the wiper, electric windows and heated seat fuses [C3416L], and the blower fan fuse [F45].
Question is - why? Is it fixing the fan or the other items.... so do your wipers, elec windows and heated seats work in key position 1 (first click), or does the fan not work in position 1, and only in position 2 (second click when the dashboard cluster powers up)? 1988 90 Td5 NAS soft top 2015 D90 XS SW |
I will check tomorrow and come back to you. I can open and close the windows without ignition, radio stays on as well, not sure what is normal and what isn't. (I mean without the key even on, or when I turn off the engine) Should the headlights stay on as well? I know it use to be the norm back in the days, but 2008, not sure. Making my Defender great again. (Or trying to at least xD)
20th Nov 2023 11:22pm |
Somebody's been playing with the electrics, definitely.
Fan and radio should work in position 1 or position 2. Electric windows and head lamps should only work in position 2. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
20th Nov 2023 11:30pm |
Ok thanks for the info. Might just remove that wire and see what happens. Making my Defender great again. (Or trying to at least xD)
20th Nov 2023 11:45pm |
