Home > Td5 > Door Cards Questions for 2002 TD5 |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6634 |
Do your doors have 1 piece pressed frames (like Puma/late Td5) or the welded/fabricated frames?
From the part number you probably have the fabricated ones, so you'd need the earlier (pre 2005) door cards. Which you need will depend on colour and whether you have electric windows or not. Central locking does not make a difference as far as I know. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
20th Nov 2023 10:06am |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
If you look inside at the top of the door frame you will be able to tell as per Martin’s response - the earlier doors have a square frame with a visible diagonal weld/seam. The later doors do not.
Will at SP 4x4 will no doubt help you if you give him a call. |
20th Nov 2023 9:18pm |
