Home > Technical > 110 Station wagon small rear window trims securing
MercianRover
United Kingdom 1998 Defender 110 300 Tdi CSW Java Black
Hello,
I swapped the small rear window trim panels between my two Defenders (I'd moved the rear speakers onto the current one before selling the other. Unfortunately they keep falling off and I think there is a clip missing from the body side but haven't had much luck with the parts book.
The photos illustrate what I have, can anyone tell me what is missing, please?
Corner clips on the trim:
Corner of body:
Post #1015416 17th Nov 2023 10:39am
2hel
United Kingdom 2003 Defender 90 Td5 CSW Java Black
Looks right to me i cant remember there being a fixing of any sort on the inside edge, should be tucked behind the side panel trim and then pushed into place near the door?
Post #1015438 17th Nov 2023 2:46pm
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
I dropped one of these the other day fitting window guards. Found it the next day and didn't have to order any, but had found the following
The Part number is MWC6203 which is superseded by BTR6682
https://www.lrworkshop.com/diagrams/land-r...trim_53578
Part number 14 in the above diagram
They are spring loaded and clip on to the trim panel but simply grip the door frame. Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #1015442 17th Nov 2023 3:48pm
Dinnu
What is said above. The barbed part of BTR6682 fits onto a fat saddle that is riveted to the trim.
At least, thats how it is on a Puma. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1015444 17th Nov 2023 4:05pm
