Home > Puma (Tdci) > Injector replacement bolt re torque? |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 556 |
ive not done mine , but I have looked at the instructions I have for the 2.2l engine.. it indicates the hold down bolt can be reused once, torqued to 6Nm and then a further 360deg, and fit a new sealing washer.. don't recall anything about re visiting after a period of time..
14th Nov 2023 3:03pm |
SilverPuma Member Since: 27 Oct 2023 Location: Devon Posts: 35 |
360 degrees would be a bit tighter at least 👍🏻 2010 2.4 TDCI Puma Defender 90
14th Nov 2023 5:05pm |
landhank Member Since: 27 Oct 2021 Location: RLP Posts: 37 |
There is always a discussion if there is a difference between the 2.4l engine and the 2.2l engine.
The instructions say 360 degrees for the 2.2l but some say that its wrong in the instruction. Anyway. I replaced the injectors on my 2.2l and 360 degrees worked fine. |
14th Nov 2023 7:41pm |
