Home > Td5 > TD5 Idler pulley bearings - Replacement
Page 2 of 2 <12
geobloke
There is just something about brand new quality bearings Rolling Eyes
Super quick delivery.
Post #1014699 10th Nov 2023 2:05pm
geobloke
Well I swapped the alternator over on old Miffy this afternoon and whilst I was in there I decided to take a look at this pulley bearing.
Short answer... Job done...! This is a very very easy job to do. I did use a vice, but to be honest I could have done it with nothing more than a socket and a lump hammer.
There are no circlips to worry about. It is just a case of pressing the old bearing out and pressing the new one in.
To remove all you need is a 1 1/4" socket. It fits perfectly onto the bearing casing without fouling on the pulley. It is a friction fit so the first bit is a little tight, but easily removed with a vice by pushing the socket through the pulley.
Clean up the pulley. Stick it in some boiling water for 10 minutes and then tap the new bearing into place. Make sure it is seated properly.
Refit to the vehicle.
The old bearing (no name or markings) had previously dried out completely and as such had a lot of axial play in the bearing. I cleaned and repacked with grease until I could do this job.
Having done it and found the bearing to use, if your pulley is in good shape then this is a very easy cost effective DIY job. No need to replace the whole thing anymore.
Details:
Timken 6303 2RS/C3
Ball bearing 17mm x 47mm x 14mm
Price: £5.50
For pulley ERR6658 (£20-90) and ERR6493 (£25-50) found on TD5 engines.
Post #1015216 15th Nov 2023 5:46pm
rustandoil
Nice one 👍🏻👍🏻
Post #1015218 15th Nov 2023 6:00pm
geobloke
Well hope it will be of use to others...
Post #1015224 15th Nov 2023 6:16pm
rustandoil
Needs to be a sticky topic ?
I will certainly keep watching as a way of keeping your info....
I will check my pulley tomorrow, easy as the belt is off at the moment 😉
Post #1015232 15th Nov 2023 7:12pm
geobloke
Good luck with the pulleys. Look for axial play and listen out for a growling around the belts at idle Thumbs Up
Post #1015328 16th Nov 2023 2:37pm
Page 2 of 2 <12
