Home > My Defender > Fuji 110 LS3 build |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2911 |
Did a quick concept this evening so pretty happy it can work with the standard cubby behind like the works. I will vac form the tunnel surround, paint it to match the fascia and then add the leather sides to match the cubby and dash etc. Alloy shifter surround.... Also can add my winch and light bar switch..
Click image to enlarge Click image to enlarge Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
9th Nov 2023 9:19pm |
That will be a tidy cockpit Andy
9th Nov 2023 9:25pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10833 |
Great work on the prep Andy as always Clayton.
mrfirepro Member Since: 06 Nov 2020 Location: kent Posts: 232 |
Fantastic work as always, cant wait to see the finished article.
16th Nov 2023 8:26pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2225 |
State of Kentucky is a great idea. I was thinking of using a map of Solihull on my doors |
17th Nov 2023 5:24pm |
Getting very close to complete. Took a while refitting all the interior in the back after the cage install but the extra weight has brought the suspension level . I decided to stick with Lazer and fitted the Triple R 28 Elite, now just need to lift the rack on.
Click image to enlarge Click image to enlarge Click image to enlarge And then settled on the final tunnel surround design. Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
19th Nov 2023 3:31pm |
First part of the new cubby/console fitted. I just had to move the cubby floor up 30 mm so that it can sit over the Chevy ECU. With this bolted down now I can do a last scan to get the tunnel surround spot on. Measure twice, cut once.
22nd Nov 2023 9:40pm |
Just small jobs now…. Added a mesh insert to the intake and black bolt kit to the cage.
Click image to enlarge Then a quick check of the graphic colours. Really hard to tell as the pictures online vary so much but I sampled these colours from some hi res pics a member here took when over at a Land Rover day with the trophy’s Click image to enlarge[/url] Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
27th Nov 2023 11:10pm |
Hi Andy
Once the graphic's are on the 110, they will be the " icing on the cake " , totally transform it Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
29th Nov 2023 8:57pm |
Yes I have had to restrain myself from sticking them on too soon before the cage and body shop. At least now when they are fitted in a few weeks that will finish the exterior work. Andy
30th Nov 2023 9:50am |
That is a job in it's self restraining ones self from getting on with it
It will all be worth it once the graphic's are on Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
30th Nov 2023 9:23pm |
Back from the body shop. Window frame painted, holes from old wheel carrier filled and just some small tidy ups. Re fitted the cage and rack with full black nut and bolt kit, plumbed in the big lazer. Beautiful new black FFRR in the graphics workshop getting wrapped Lambo green ahead of me. I am crying at the green wrap btw.
Click image to enlarge Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html Last edited by mcma1 on 18th Dec 2023 7:17am. Edited 1 time in total |
16th Dec 2023 4:55pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Looking great! Can't wait to see with decals on! James
16th Dec 2023 5:17pm |
Coming together nicely now Andy
I watched a you tube with the charity run in London and they had an original Trophy 110 and some of the information that he was telling you about the graphic's for instance was very interesting &t=3s&pp=ygUZbG9uZG9uIGxhbmQgcm92ZXIgY2hhcml0eQ%3D%3D &pp=ygUZbG9uZG9uIGxhbmQgcm92ZXIgY2hhcml0eQ%3D%3D I've watched both and i can't remember which one the information is in Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
18th Dec 2023 8:47pm |
