Home > My Defender > Fuji 110 LS3 build
Page 52 of 61 <123 ... 515253 ... 596061>
Black Puma
United Kingdom 2011 Defender 90 Puma 2.4 SW Sumatra Black
Even the process is eye candy. Thank you for sharing.
I love the inspiration from this forum, just makes a good day or a bad day better!
Thumbs Up
Post #994217 27th May 2023 1:15pm
mcma1
blasted and ready for the next stage..
 Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #994657 31st May 2023 6:41pm
robbie9999
Canada 2008 Defender 110 Puma 2.4 PU Keswick Green
mcma1 wrote:
Just about given up hope with Falon nameplates for some custom badges so back to the printing and tried a different approach.
Now an assembly. This allows me to finish the silver aluminium and also then the inner black as separate parts. The black parts are finished in a textured satin to give the effect of a cast finish.
The silver sits just 0.2mm above and clearance is 0.1mm so when all together it looks like a single piece.
Then 4 dummy rivets so I can just stick the badges on with 3m tape.
This CNC stuff is done really well Andy !
Post #995576 8th Jun 2023 1:02pm
mcma1
Post #995577 8th Jun 2023 1:24pm
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
They look great Thumbs Up
How's the accuracy with which ever printer you used? did it require some filing or is it a reassuringly tight fit? 4.0 V8 Defender 90
My Instagram
Post #995589 8th Jun 2023 2:41pm
mcma1
Just the latest Prusa printer, after a few tests it more or less clipped together. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #995617 8th Jun 2023 4:35pm
mcma1
Moved it from the shed to wash off the dust. Next job is to fit the cage, rack and Lazer 51" light bar and then finally the graphics. Inside nothing really, just the mats and steering wheel and have removed the alloy parts. Surprised how much the alive front springs dropped with the winch so I am fitting some Disco 2 spring isolators to lift it level, may even need to revert back to the standard springs.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1010404 7th Oct 2023 2:37pm
JOW240725
Still looking great!
How's the LS3 behaving, everything OK? James
Instagram @suffolk_rovers
Post #1010414 7th Oct 2023 4:26pm
mcma1
Really looking forward to getting these printed next week. Test fitted the blank stencils and all spot on.
I basically traced the images I had onto the 3D scan and then brought all the layers together in Coral Draw. Took a lot of time as both sides are unique. With addition to the Trophy countries I have added the state of Kentucky to represent the LS3 Rolling with laughter
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1011205 14th Oct 2023 1:36pm
Co1
This is going to bonkers good! Can’t wait to see it on the landy itself. Nice touch on the Kentucky map as well. Thumbs Up
Post #1011211 14th Oct 2023 2:26pm
mcma1
Delivered back from Redman Engineering today after having the roll cage fitted, standard springs and D2 isolators fitted, new gear stick location and lots of other things! Body shop next for some tlc and then a nice build back up and graphics.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1014021 5th Nov 2023 5:22pm
mcma1
Took a fresh scan of the interior this evening to get the position of the new shifter, it has moved approx 5" forward now, and raised, feels more like the original. I will need to now create my complete own design but I will base it mainly around the works setup combining some Santorini vac formed plastic and leather, with standard cup holders. Could someone confirm for me the approx width of the standard XS cubby please?
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1014459 8th Nov 2023 9:00pm
Co1
This is next level Andy! Keep the updates coming.
Post #1014492 9th Nov 2023 5:07am
I took this the other day for somebody who was asking about the size of the cup holder, which may help:
 Darren
Post #1014513 9th Nov 2023 8:48am
mcma1
Perfect thanks Darren, just what I need Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1014574 9th Nov 2023 7:02pm
