Home > Maintenance & Modifications > M57 questions !
Page 2 of 4 <1234>
Mo Murphy
The M57 has so much torque that I can't see an overdrive being of any use, just fit higher transfer box gearing, its easily capable of pulling it.
50 Shades of Pennine Grey
Post #1014371 8th Nov 2023 12:14pm
geobloke
Fair enough Mo. Thumbs Up
Post #1014372 8th Nov 2023 12:19pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
Following this with interest. Still tempted by an M57 despite geobloke swaying me towards a Td5 when we met earlier in the year Rolling with laughter 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #1014373 8th Nov 2023 12:46pm
Mo Murphy
Its so much more than a TD5, Shroppy!
Post #1014494 9th Nov 2023 6:37am
BrickBox
As above - I’d say the M57 is leagues ahead combined with the auto box.
TD5 wouldn’t be a consideration out of the 2. 2008 2.4 110 Utility Station Wagon XS.
Post #1014511 9th Nov 2023 8:34am
barbel jim
It’d be interesting pairing a box with a td5 engine. The ratios in the r380 is rather limiting. A tuned td5 will produce similar figures for a fraction of the price. Personally I wouldn’t spoil a perfectly good td5 for the conversion, but if I still had my 2.2 I’d be chomping at the bit Laughing
Post #1014601 9th Nov 2023 8:43pm
geobloke
I know I know... A guy is allowed to potentially change his mind you know Rolling Eyes Rolling with laughter I am still wary of all the plastic, but I get why folks are keen on the idea.
Post #1014603 9th Nov 2023 8:55pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
jst wrote:
I have done an mt82/184 for my 90.
Am about to do a n2 6hp to my 130.
I have gone demand engr for exhaust for the n2.
Centre console there are some options coming, ask Marcus.
For my 130 i am fitting his air solenoids, have orders them too..Will run them off my t max compressor which is under drivers seat. Air res is an a6 air suspension res, cheap manifold off ebay with pressure switch.
Hi James
Thank you for the tips. I havn't spoken with demand yet but will do tomorrow. Did you give them precise measurements or have they previously jigged one up ?
Tried to get hold of Marcus, I know he's a busy chap. Messaged another guy on FB who seems to be working with MW to get a cubby. Also messaged Lucari who were very prompt to reply and happy to do it, subject to placement of shifter and switches.
What size is your TMAX compressor and does it need a seperate resovoir bottle for the air suspension ?
I have to say, it would be great if I could get one man enough to pump up various bits and pieces and run air tools but not entirely necessary ! https://www.instagram.com/hustynminepark/
Post #1014604 9th Nov 2023 9:01pm
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Hi Blue ricky
no just tell Demand you fitted a M57 and if its a 90 or whatever
Post #1014686 10th Nov 2023 12:03pm
Chicken Drumstick
Has to depend on what your starting point is, how much you want to spend and who is physically doing the conversion.
The Td5 is a fine engine and of course an engine factory fitted by Land Rover in the Defender. So if you want to keep it factory, it is a good choice. And moderately easy to make it look like a factory install.
Lots of Td5 engines available for little money too and few alterations needed.
If you have a 300Tdi or later (excluding Tdci), it should be an easy swap. If its a 200Tdi or older then it is more work.
The M57 will be a more expensive choice and while the engine was used in the L322, you will end up with custom parts to complete the build. There are also a number of different approaches to fitting this engine depending on what gearbox you want to use and what vehicle you source the engine from. While it is a proven path, it is a far more complex engine swap and I'd guess likely to cost 2 or 3+ times more than a Td5 swap.
The biggest reason to go for the M57 is power. If you don't plan on tuning it or making use of more power. You'd have to question why go down that route. But bigger power may also require other upgrades too.
That all said and done, there are still lots of other engine swap options too. If MPG isn't your primary concern there are some interesting petrol engines to consider.
Post #1014691 10th Nov 2023 12:50pm
Shroppy
Without wishing to hijack this thread:
Starting point: 1985 127, 3.5 V8 (original), but the vehicle is undergoing a full rebuild and I have a new 4.6 and R380 in storage that was originally destined for it.
Budget: Healthy but not endless.
Who is doing the work?: Me Cool
Given that the GVW will be 3450kg, and it will be used to tow 3500kg, power is definitely a consideration. A petrol V8 would be my preference, but I can't completely rule out fuel economy given that it will be a vehicle for exploring and to a small extent, work. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #1014694 10th Nov 2023 1:45pm
jst
Hi James
i didn't give any dims for down pipe, think he has a jog, depending on engine type you need to specify sensors needed or not.
Lucari offer a cubby box/gear selector locator option?
i run a single head T max compressor that feeds an air manifold. this in turn has the pressure switch fitted to it. plus outputs to axle lockers, PCL fitting and an air reservoir. i have used A6 air suspension res in the past for this job but any air res will do it. its a reasonably cheap was of fitting air to a vehicle.
compressor
https://www.ebay.co.uk/itm/115954559099?ch...gIlW_D_BwE
Manifold
https://www.ebay.co.uk/itm/131905797277?ha...R5b-kpj3Yg
Air Pressure switch
https://www.ebay.co.uk/itm/325309396165?ha...R-SOnJj3Yg
some 6mm push fits, some blanking plugs,some 6mm pipe.
air res:
https://www.ebay.co.uk/itm/166227838976?ep...R_72ppj3Yg
these arent the actual items i have just the ones that showed first on a search but you should get the idea.
i have several of these running, longest setup is in my 110 that was fitted 2012.
Hope this helps
James Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1014696 10th Nov 2023 1:57pm
jst
i am similar with my 130. going from 2.4 to m57n2 auto with 1.3 box on 235/85s. i want the torque.
its not the engine thats expensive its the conversion kit. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1014697 10th Nov 2023 2:00pm
Chicken Drumstick
There is still something about a Rover V8. A 4.6 is a good way to 200-250hp, but there is no denying it'll like a drink.
My p38 is currently showing 13.8mpg, which really hurts the wallet with fuel prices these days.
If you want more power then supercharing the RV8 is an option. Several ways to do this on a home build. The RV8 will make a better noise than the M57 and be smoother. And I'd think power could be similar given a similar budget considering you already have the 4.6
So it really comes down to mpg. LPG is really the only way to reduce pence per mile costs with the RV8. But won't be for everyone.
Other petrol engines I think would be interesting. BMW 6 pot as per the S. Africa variant. The 2.8 can easily make cira 230hp and if you coupled it with a 1.6 transfer box and a Roamerdrive I think it would make for a nice alternative to an RV8. Although probably slightly less low end grunt and a bit more revvy.
Probably slightly cheaper than the M57 conversion but similar. Biggest advntage is petrol refinement and power delivery vs the diesel.
Chevy LS has to be on the list too I'd have thought. Crate engines are well priced and likely to cost similar to the M57 conversion. Sadly no good manual conversions though, they are mostly automatics.
My top engine choice however would be a Jaguar V8. As it is also a Land Rover engine. Good choice from 300hp 4.2 and 4.4 options plus supercharged options. Either wholesale with the auto or my preferred choice with the ZF 6 speed manual. Bit more work than an RV8 but a much more modern engine. Suspect MPG won't be massively better, but you should be talking more power.
For a 130 I think I'd also be considering a Cummins swap too if you really want to go diesel.
Nothing against the M57, it is kind of on my list too although I probably would not consider a Td5. I have an LT-77, so would need to change gearboxes, maybe seat box and perhaps props. Which seems a lot of work to just go to a Td5. Guessing you probably have an LT-85 with the V8, so you are in a similar boat.
Post #1014717 10th Nov 2023 4:18pm
Shroppy
Agreed, Rover V8s are lovely, just not comparable with modern V8s.
An LS3 is on the cards, but I've yet to see any solid MPG figures and whilst it's not a dealbreaker, I can see it not getting the use it ought to if it only managed low-mid teens. Quite tempted by the Ford Coyote 5.0L, but it's a less common swap...
Cummins are phenomenal engines, but too much for a Land Rover IMO.
M57s are undoubtedly excellent engines, but I'm just not sold on them yet.
If going to all the effort, I'd probably go automatic. Whilst I love driving a manual, there is a lot to be said for a modern(ish) auto box. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #1014762 10th Nov 2023 8:50pm
Page 2 of 4 <1234>
