Home > Tdi > R380 Serial Number - Assistance Required Please
TomB8
United Kingdom 1994 Defender 110 300 Tdi HT Arles Blue
Hello good people,
I need to replace (at least I hope this is all that is causing my clutch to bite low and pedal need some assistance in returning) the clutch slave, master, flex pipe and spring.
I have been looking at slave's and they say FTC5202 from 56A0669087K or FTC5072 pre 56A0669086K.
Had a look and my number appears as 56A 0310755J (as in the photo below) but I can't quite make out if there is a 2 or another number in the space between the A and 0.
Did any R380's have 8 digit numbers? The photos I have found only show stamped numbers (not what looks like computer engraved on mine) and don't have any spaces.
Just need to figure out if I need FTC5202 or FTC5072.
Any help from someone more knowledgeable than I would be greatly appreciated.
Post #1014298 7th Nov 2023 10:52pm
geobloke
No there is not a character between the A and 0. So you want the pre 006 part.
Post #1014299 7th Nov 2023 11:03pm
TomB8
Thank you, sir. Much appreciated!
Post #1014304 7th Nov 2023 11:24pm
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
I made this video to help identify the slave cylinders in case someone had changed them and the push rod, in which case the gearbox number would be irrelevant
?si=sDiINlBfHz010L_e LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #1014442 8th Nov 2023 8:32pm
geobloke
Good call Will Rolling Eyes and a really useful video Thumbs Up
Post #1014448 8th Nov 2023 8:41pm
TomB8
Thanks, Will. I will have a look at this later.
Hope no one had Censored about in the past. I expect not given the vehicles history but you never know!
I managed to watch a bit of your video and saw you were being careful with the pushrod. Most videos don't seem to mention being careful not to let it come out. Having done a little reading I understand it is not good. Aside from being careful and some wiggling and jiggling are there any tips to help stop it coming out?
Post #1014456 8th Nov 2023 9:42pm
TomB8
Well the rod came out, didn't feel anything unclip though and can't see any sign of a clip in there.
Am I right in thinking that if there was a clip and it had come off with the rod it would be in there still or on the floor somewhere?
Have been in with a boroscope but there's nothing! Sorry the photo is upside down
Post #1014806 11th Nov 2023 3:12pm
