![]() | Home > Td5 > TD5 Idler pulley bearings - Replacement |
So, I have fallen foul of fitting a replacement pulley to Miffy without checking whether the bearing inside the pulley had any grease. Nope, pretty much dry as a bone in there. So I have greased it, but it will need replacing at the next service.
The pulleys in question are: ERR6658 - Idler pulley all engines. ERR6493 - Idler pulley non-AC I suspect they are the same bearing inside, but does anyone else know for certain? Any bearing part numbers for SKF or Timken or alike? A quick search provided these measurements for ERR6493 ID: 17mm OD: 47mm W: 14mm From this website https://www.bearingoptions.co.uk/replaceme...ey-bearing |
Ok, confirmation through a deep dive into the search panel gives me this thread
https://www.defender2.net/forum/post941642.html So both pulleys use the same bearing. That is one question answered. ![]() and the bearings both had 6303 LHA embossed on them, which is the same bearing, according to a Russian site as SKF 6303.2RSR.C3. So, looks like I am heading in the right direction. |
A bit of extra learning this evening. To tell you the truth I have never paid attention to what the numbers on bearings actually mean.
So the 6303 2RSR C3 code means: The '6' = Deep groove ball bearing (single row) - Suitable for light axial loads as well as radial loads. '303' = Bore diameter I believe '2RS' = Bearing with rubber seal on both sides. RS provides a better seal but more rolling friction than 2Z (Bearing with metal seal on both sides) '2' = TBC C3 = Internal clearance code. Fascinating really, well it is to me anyway. |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1435 ![]() ![]() ![]() |
I did mine not that long ago, and genuine land rover were on back order
And probably will be for quite some time I would expect.
Apparently the above bearing code is the OE bearing used on some Mercedes Benz's. OE 990 990 74 00 — MERCEDES-BENZ OE A 990 990 74 00 — MERCEDES-BENZ OE N 000625 436303 — MERCEDES-BENZ |
I believe this is where my issue stems from. Poor quality bearings that may or may not have been greased. The pulleys seem fine and I hate to throw away perfectly serviceable items, hence replacing the faulty bearings.
Goodness, prices go up and quality goes down... ![]() |
Bearings ordered
![]() Buying the full pulleys would cost £55.05 before P&P for Britpart items and a whooping £159.61 for LR items ![]() Just need a little vice and drift action and job done. |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2128 ![]() ![]() ![]() |
Ah Timken - Carlsberg
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 810 ![]() ![]() ![]() |
This is good stuff, well done for searching out the bearing numbers
No problem. I will see how feasible the bearing swap actually is when they arrive
It would be great if you could report back here with your results
Of course. Goes without saying
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17679 ![]() ![]() ![]() |
I did a similar exercise not too long ago on my 2.4 Puma and replaced nearly all of the supposedly non-replaceable bearings. It was relatively quick, relatively cheap, and hugely satisfying!
It is all about the satisfaction
