![]() | Home > Td5 > Noisy fuel pump |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 917 ![]() ![]() ![]() |
I would start with a purge cycle. Turn the ignition to the second position and pump the accelerator pedal five times. The engine light on the dash will start flashing and the pump will make all sorts of noises. Let it do its thing for a few minutes. Hopefully the pump is noisy purely because you have introduced air into the system. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
Jim88er Member Since: 12 Jan 2022 Location: East Sussex Posts: 11 ![]() ![]() ![]() |
I meant to say I've done the full purge cycle a good few times
458GT Member Since: 22 Jun 2022 Location: Warwickshire Posts: 85 ![]() |
Did you solve this in the end?
Mine has just started to go a bit noisy.... air purge'd a few times without much success. Have filled with a millers additive just incase it was poor diesel, hoping to solve the issue... Likely will change fuel filter and perhaps air bleed valve at the next service upcoming. |
Is the noise a constant whir or a gurgling like air is being purged from the system?
Former is likely an ageing pump, latter could be the same, but might also indicate air getting into the system through the FPR, fuel filter housing ports or somewhere else. |
It's more of a constant whir and very audible.
If we are at a fuel pump ageing, at what point does it begin to become obvious closer to failure (obviously still driving it)? I've noticed the fuel gauge has also misbehaved too. It was initially reading full as it was full, then after a 60 miles motorway run decreased normally. However following day started up, the gauge rose very slowly to about half....Upon refilling it only took approx 8 litres before being full and gauge reads full again ![]() Can fuel pump / fuel gauge issues all be linked? |
I've just done the pump today and my problem was definitely that. New Siemens pump seems to have fixed it
DefenderSTW Member Since: 27 Nov 2023 Location: South Wales Posts: 9 ![]() ![]() ![]() |
Unfortunately I had to go through the fuel pump replacement. Being a bit of a novice on Defenders but generally will tackle most jobs, I decided to give it a go. As it’s a complete
![]() https://www.youtube.com/watch?v=8m1BitUpjDs I used a Dremel and just took my time, all in all it took about an hour to cut the hatch, about 30 mins to tidy up the cross members and another 30 to give it all a good clean up. Installing the new pump took about 30 minutes and I opted to change the fuel filter at the same time. |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2181 ![]() ![]() ![]() |
Good plan and it’s on my to do list - I’ve purchased the marine hatch and I have the Dremel - just need a bit of motivation - and by that I don’t mean the pump failing
Well that’s one less thing on my long to do list…
Please note - all I did was fit the hatch - not replace the pump 👍 ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Added bonus is that due to the number of layers of flooring/insulation/carpet/vinyl in the back, you can’t actually feel the hatch under your feet 👍 |
