Home > Td5 > Noisy fuel pump
Jim88er
England 1999 Defender 110 Td5 CSW Alpine White
Noisy fuel pump
I rebuilt my td5 engine and when I first cranked it over the fuel connection on the fuel cooler was loose and pumped diesel all over the alternator, needless to say a few days later I had to fit a new alternator. When I did this I didn't want to loose all the de-ionised water and coolant I'd just put in it and I had a spare inlet manifold gasket so I took the fuel cooler and inlet manifold off to get to it. The next day when I was driving it I noticed that the pump was very noisy and it's very loud it the engine bay too. Could I have disturbed something whilst changing the alternator or do you think it's coincidence and the pump has failed? I had new genuine injector washers put on 3000 miles ago with an AMC head so I'm guessing it's not them. Thanks, Jim.
Post #1007403 12th Sep 2023 6:12pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
I would start with a purge cycle. Turn the ignition to the second position and pump the accelerator pedal five times. The engine light on the dash will start flashing and the pump will make all sorts of noises. Let it do its thing for a few minutes. Hopefully the pump is noisy purely because you have introduced air into the system. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #1007481 13th Sep 2023 11:43am
Jim88er
I meant to say I've done the full purge cycle a good few times
Post #1007492 13th Sep 2023 2:30pm
458GT
Did you solve this in the end?
Mine has just started to go a bit noisy.... air purge'd a few times without much success.
Have filled with a millers additive just incase it was poor diesel, hoping to solve the issue... Likely will change fuel filter and perhaps air bleed valve at the next service upcoming.
Post #1013835 3rd Nov 2023 8:54pm
geobloke
Is the noise a constant whir or a gurgling like air is being purged from the system?
Former is likely an ageing pump, latter could be the same, but might also indicate air getting into the system through the FPR, fuel filter housing ports or somewhere else.
Post #1013900 4th Nov 2023 1:39pm
458GT
It's more of a constant whir and very audible.
If we are at a fuel pump ageing, at what point does it begin to become obvious closer to failure (obviously still driving it)?
I've noticed the fuel gauge has also misbehaved too. It was initially reading full as it was full, then after a 60 miles motorway run decreased normally. However following day started up, the gauge rose very slowly to about half....Upon refilling it only took approx 8 litres before being full and gauge reads full again Confused
Can fuel pump / fuel gauge issues all be linked?
Post #1013955 4th Nov 2023 9:04pm
Jim88er
I've just done the pump today and my problem was definitely that. New Siemens pump seems to have fixed it
Post #1016211 23rd Nov 2023 8:37pm
DefenderSTW
United Kingdom 1999 Defender 90 Td5 SW Firenze Red
Unfortunately I had to go through the fuel pump replacement. Being a bit of a novice on Defenders but generally will tackle most jobs, I decided to give it a go. As it’s a complete Censored to get to, I opted to cut a hole in the rear floor and install a port hole hatch in case it ever needs doing again. If anyone is interested, I followed this video and the dimensions were bang on.
https://www.youtube.com/watch?v=8m1BitUpjDs
I used a Dremel and just took my time, all in all it took about an hour to cut the hatch, about 30 mins to tidy up the cross members and another 30 to give it all a good clean up.
Installing the new pump took about 30 minutes and I opted to change the fuel filter at the same time.
Post #1016609 28th Nov 2023 9:46am
Screbble
Good plan and it’s on my to do list - I’ve purchased the marine hatch and I have the Dremel - just need a bit of motivation - and by that I don’t mean the pump failing Rolling with laughter
Post #1016657 28th Nov 2023 8:47pm
Screbble
Well that’s one less thing on my long to do list…
Please note - all I did was fit the hatch - not replace the pump 👍
Added bonus is that due to the number of layers of flooring/insulation/carpet/vinyl in the back, you can’t actually feel the hatch under your feet 👍
Post #1019447 28th Dec 2023 5:13pm
