![]() | Home > Td5 > Steering shaft swap/heavier steering |
Sounds like the UJs are dry or tight. Anyway you can get some lube into them?
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5883 ![]() ![]() ![]() |
It does seem that way. Thinking back to how long I've had the shaft, its a few years since its been used and in that time it been in storage.
I have some three in 1 oil i could try or wd40. Its a pain the new part has got just a wee bit of play in one UJ. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 956 ![]() ![]() ![]() |
Forget WD40, its a poor lubricant (unless its their penetrating oil) its a great water dispersant and cleaner though. Suggest you use use the 3 in 1 oil 👌🏻 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
I found some 3 in 1 and also some GT85 spray with PTFE. The UJs got a good squirt with this and I left a pool of 3 in 1 in the UJ cup with the hope, the oil will seep in. 1999 Defender TD5 110
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 672 ![]() ![]() ![]() |
I had this problem after changing the upper steering shaft. It was simply that I had refitted the steering wheel with the indicator collar out by 90 degrees. Was quite a relief when I worked it out.
Cheers. I will check this as i did remove steering wheel and did notice that the indicator was not staying on. 1999 Defender TD5 110
Reset the steering wheel and early indications are its seems better...Fingers crossed 1999 Defender TD5 110
Hopefully a simple fix
It was a simple fix. Steering wheel reset back to how it should be and all good. Cheers for the tip! 1999 Defender TD5 110
