Home > Td5 > Oil on turbo to intercooler pipe
excossack
While under the bonnet of the 110 earlier today, I spotted oil on the putside of the turbo to intercooler pipe. This was cleaned the other week when I removed the pipes, but oil has returned.
The oil return hose from the turbo is clean.
Not sure were the oil has come from. More investigation required when the rain has gone and darkness is not here! 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1013232 30th Oct 2023 5:54pm
barbel jim
Probably be from the crank case breather.
Post #1013267 30th Oct 2023 8:37pm
excossack
Cheers. I guess it could be from the PCV valve. I will break out the cleaning spray and a cloth and see what I can find. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1013269 30th Oct 2023 8:42pm
barbel jim
I think they’re service items….
When my pcv was blocked, I also had oil on top of the rocker box
Post #1013274 30th Oct 2023 8:55pm
NickMc
Loose oil filter makes a mess and happens too.
Post #1013277 30th Oct 2023 9:06pm
excossack
Pretty sure thats OK, but I will check 1999 Defender TD5 110
Regards
John M0VAZ
Post #1013278 30th Oct 2023 9:07pm
excossack
Oil filter is nice and snug with no excess oil on the filter. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1013310 31st Oct 2023 8:14am
geobloke
Re: Oil on turbo to intercooler pipe
Was the oil a slick or just a residue on the silicone hose?
Eventually the silicone hose can become porous and ooze oil under pressure. This happened to Miffys previous set of silicone hoses. c. 10 years old.
Post #1013508 1st Nov 2023 12:09pm
excossack
Hi Guy, More of a light misting really and they are a few years old. I wonder if it is as simple? 1999 Defender TD5 110
Regards
John M0VAZ
Post #1013510 1st Nov 2023 12:10pm
geobloke
It could be. I had a chat with Garry at Alive about it and he told me that when it happens you get a light covering of oil, sometimes a defined droplet or two. It does not drastically affect performance, just makes things greasy. I swapped out the hoses, problem cured.
Post #1013514 1st Nov 2023 12:25pm
barbel jim
My PCV caused a misting, and a small pool on top of the rocker were the breather connects. My hoses were only 12 months old so made it easy. Plus a pcv is only a few ££
Post #1013525 1st Nov 2023 1:31pm
