Home > Td5 > Oil on turbo to intercooler pipe |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 |
Probably be from the crank case breather.
30th Oct 2023 8:37pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5883 |
Cheers. I guess it could be from the PCV valve. I will break out the cleaning spray and a cloth and see what I can find. 1999 Defender TD5 110
30th Oct 2023 8:42pm |
I think they’re service items….
When my pcv was blocked, I also had oil on top of the rocker box |
30th Oct 2023 8:55pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1661 |
Loose oil filter makes a mess and happens too.
30th Oct 2023 9:06pm |
Pretty sure thats OK, but I will check 1999 Defender TD5 110
30th Oct 2023 9:07pm |
Oil filter is nice and snug with no excess oil on the filter. 1999 Defender TD5 110
31st Oct 2023 8:14am |
Was the oil a slick or just a residue on the silicone hose? Eventually the silicone hose can become porous and ooze oil under pressure. This happened to Miffys previous set of silicone hoses. c. 10 years old. |
1st Nov 2023 12:09pm |
Hi Guy, More of a light misting really and they are a few years old. I wonder if it is as simple? 1999 Defender TD5 110
1st Nov 2023 12:10pm |
It could be. I had a chat with Garry at Alive about it and he told me that when it happens you get a light covering of oil, sometimes a defined droplet or two. It does not drastically affect performance, just makes things greasy. I swapped out the hoses, problem cured.
1st Nov 2023 12:25pm |
My PCV caused a misting, and a small pool on top of the rocker were the breather connects. My hoses were only 12 months old so made it easy. Plus a pcv is only a few ££
1st Nov 2023 1:31pm |
