![]() | Home > Technical > 300 TDI Speedo Cable removal (From Gauge) |
Cubflyer Member Since: 25 Sep 2021 Location: Suffolk Posts: 278 ![]() ![]() ![]() |
Hi folk
I'm sure this question has been asked many times but I can't fins the answer! How do I remove the cable from the gauge please? ... really need working space behind the instrument panel. MTIA John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
Thanks Dinnu
Yep that worked! ![]() All the best John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 ![]() ![]() |
Don't know if the connection on the back of the speedo is the same as earlier vehicles but this is why I loved my 2-piece speedo cable so much.
You break the connection under the bonnet and that allows you to pull the cluster off a bit further and gives you more room to remove it from the back of the speedo. ONE LIFE, GET IT! |
Hi Litch ... Sounds an excellent idea but sadly my cable is a one piece unit.
What age is your 90? 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
