  • You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Technical > 300 TDI Speedo Cable removal (From Gauge)
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
Hi folk
I'm sure this question has been asked many times but I can't fins the answer!
How do I remove the cable from the gauge please? ... really need working space behind the instrument panel.
MTIA
John 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #1012455 24th Oct 2023 2:18pm
Dinnu
I think it had not changed all the way up to 300tdi, but on older LandRovers, you need to press on two sides of the white plastic end so that it ovals, and then it releases itself. You need to press on the correct sides though. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1012458 24th Oct 2023 2:30pm
Cubflyer
Thanks Dinnu
Yep that worked! Smile Sadly could not do it with my hands so had to use a pair of slip pliers (jaws padded).
All the best
Post #1012497 24th Oct 2023 6:31pm
Litch
Don't know if the connection on the back of the speedo is the same as earlier vehicles but this is why I loved my 2-piece speedo cable so much.
You break the connection under the bonnet and that allows you to pull the cluster off a bit further and gives you more room to remove it from the back of the speedo. ONE LIFE, GET IT!
Post #1013494 1st Nov 2023 10:42am
Cubflyer
Hi Litch ... Sounds an excellent idea but sadly my cable is a one piece unit.
What age is your 90? 2010 Defender 90 300Tdi CW (White/1994)
Post #1013495 1st Nov 2023 10:53am
