![]() | Home > Puma (Tdci) > Door outer skin near waist seal acting as a bucket!! |
WestCountryPete Member Since: 30 Sep 2023 Location: Wiltshire Posts: 43 ![]() ![]() ![]() |
Should probably add that the seals are new and the gap is larger than it looks in the photos.
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2147 ![]() ![]() ![]() |
There’s slightly less of a gap on mine except for in the centre where there’s a random rivet head. Mind appears to be sitting slightly lower than yours and therefore sealing tighter.
Did you ‘help’ the seal down using a block of wood and a mallet? Don’t forget that at either end you have a gap/hole where the seal sits behind the door skin. You may want to seal those. Are you sure the water ingress isn’t from the million other known sources? Good luck 👍 |
Thanks for the reply. Yeah, I “tapped” it down and compared the height of the mounting ridge to the driver’s side and looks ok. You’re right though, it’s the middle that’s the issue where it widens. Drivers side is consistent along its length, give or take a mm.
My plan is to improve the shedding layer so it keeps the water inside the door and down to the drain holes, but reducing the water getting in there would be ideal. Will dig out the butyl tape and seal up the corners anyway. |
