![]() | Home > Puma (Tdci) > proper application for the rear seats (6th & 7th) |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
Nice job! Also ensures a safe(r) storage 👍
Very neat. Is it stable with just one person seated? Darren
khamuul Member Since: 14 Oct 2017 Location: Teutoburg Forest Posts: 24 ![]() ![]() ![]() |
Yes it is very stable for one 90kg person - so maybe even more.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
Like it, very good. Do you have the lengths of each part if anyone wanted to make their own exactly the same?
Sure:
![]() Click image to enlarge Keep an eye on the exact height oft this thing. (180mm) Otherwise the seats' locks wont like to catch the bottom brackets. I would be happy to see a photo here if someone builds a similar rack. ![]() Best regards, Martin |
I forgot: You would have to drill holes 60mm from the edge for the top hinges' M8 stud bolts - with bigger diameter from the bottom in order to be able to screw nuts with washers. (on the top (480mm) bar)
![]() Click image to enlarge ![]() Click image to enlarge |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1094 ![]() ![]() ![]() |
