Home > Technical > Defender 90 300 Tdi (1994)
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
Evening all ...
Can somebody help please?? I've just been doing a bit of corrosion prevention under the bonnet and would appreciate your help please.
Firstly (Number 1 in the picture) had some flaky surface rust on the plate held by six slotted screws. What's under the plate and why does it have a rubber seal??
I want to remove the six screws and replace with new ones ... Any problems to be aware off???
Secondly (Number 2 in the picture) is a purple wire coming through the bulkhead to a dead end (Insulated) ... comments please???
Many thanks
John
(Learning by the day Smile ) 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #1012896 27th Oct 2023 7:14pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
1. Clutch master cylinder. The seal is to try keep water off your foot.
2. I don't know.
Post #1012904 27th Oct 2023 7:55pm
Dinnu
Re: Defender 90 300 Tdi (1994)
They are not standard metric screws, but are more like self cutting screws.
I have purchased SL510031 for my Puma. They are Philips (or Pozi) heads, but not replaced them yet, so unsure if the threads are an exact match. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1012934 28th Oct 2023 7:08am
TexasRover
Purple wire is typically for the door switches (purple blue or is it purple white?). I hazard a guess that this wire is for the bonnet switch that is not fitted on your car?
Post #1012940 28th Oct 2023 7:59am
Cubflyer
Hi Dinnu ... Yep, removed them today and as you say "Non standard".
I'm very tempted to tap out to standard M5x0.8. One issue is getting the bottom left hand hole tapped because of the Brake Servo unit being in the way. 2010 Defender 90 300Tdi CW (White/1994)
Post #1013030 28th Oct 2023 10:46pm
Cubflyer
Having cleaned the cable carefully, it's colour is Purple/Red ... any thoughts folk please
Certainly there is no bonnet switch on my 1994 Defender 90 2010 Defender 90 300Tdi CW (White/1994)
Post #1013031 28th Oct 2023 10:49pm
Cubflyer
Hi Dinnu ... Just a point of note, I elected to get a replacement Clutch cover and gasket (and screws) as mine were in poor shape.
I ordered from "Boltonbits" (eBay item eBay Item No. 235181059981) and they arrived this morning. Cover and Gasket great but they supplied standard M5 slotted round heads.
... So I "Did" decide to tap out the original holes to M5. The bottom left hole was not straight forward because of the closeness to the back of the Brake Servo Unit. I took the M5 tap and put an 8BA spanner on the flats of the tap and eased it through that way.
John 2010 Defender 90 300Tdi CW (White/1994)
Post #1013358 31st Oct 2023 3:04pm
Dinnu
Disappointing to read the ebay advert that claims
Quote:
& Six Correct slotted new screws
Guess M5 would work, but I am the Original, Original, Original type of person. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1013382 31st Oct 2023 4:57pm
Cubflyer
Yes ... a little mis-leading.
Glad to hear you like "Original" ... someday you just "may" have a problem
For me "Metric" through and through Thumbs Up 2010 Defender 90 300Tdi CW (White/1994)
Post #1013384 31st Oct 2023 5:07pm
Rednaxela
Why did you need to replace those screws anyway?!
Post #1013957 4th Nov 2023 10:25pm
Cubflyer
... because they were badly corroded! 2010 Defender 90 300Tdi CW (White/1994)
Post #1013959 4th Nov 2023 10:39pm
