Home > Td5 > Help - Td5 with no throttle response - Dundee/Forfar
VVS210
Folks,
Hopefully mods will allow this post given the circumstances, if not my apologies & please remove.
I'm trying to help out a chap on another forum who has got a dead Td5 Defender, he's just moved to an area, doesn't know anyone who can assist & has a vehicle that needs 'lifting' just to get it to a garage who may or may not be able to assist.
Situation is this:
"My 23yr old SWB Defender TD5 engine management warning light has just come on and staying on and no throttle available at all, starts up first time and ticks over no problem.
I had to drive through some deep water last week with no sign of a problem after doing so and running well, got back parked it up and not used for a couple of days went out this morning to the above problem."
Chap is between Dundee & Forfar.
Anyone got any first hand recommendations for independent/specialist mechanics who are mobile in that area? Or maybe someone themself able to help with a Nanocom plug-in/throttle pedal swap out etc.
Nothing in it for me apart from the satisfaction of (hopefully) being able to help out a fellow LR owner.
Thanks in advance.
Post #1012517 24th Oct 2023 10:29pm
landy andy
If it starts and run fine, but as soon as throttle is pressed warning light comes on and then no throttle response. That is classic signs of the warn/chaffed/damaged potentiometer (throttle pedal).
Can’t help with a garage.
Post #1012530 25th Oct 2023 8:36am
TexasRover
Second the (electric) throttle paddle, possibly not helped by driving through deep water.
Despite what the sales brochures make you believe these cars are not quite invincible you know.
I lived in Houston and cars (any cars) and deep water don't mix in the long run. Too many connectors and electronics that give up weeks/months after.
Absolutely not worth wading into deep water, unless you are in a true emergency that would justify you potentially writing off your vehicle and even then going slow is better than fast.
Post #1012547 25th Oct 2023 10:06am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Plug in a scan tool it will likely tell you the throttle pedal switch is not working. You can remove it and try cleaning the plug and pins but when it fails its usually the pot in the pedal assembly, but worth a shot.
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1012591 25th Oct 2023 2:57pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
I had the same issue a few months back. Driving along in the rain when suddenly the accelerator stopped doing anything, engine went to idle with MIL light on. Ignition off and on fixed it, it's not happened since.
As far as I know, only the Throttle position sensor or Crank position sensor can trigger the MIL warning light. The engine will not run if it was the CPS so definitely the throttle or throttle wiring at fault. Most of the time a wire will have rubbed somewhere (usually against the gearbox) causing a loss of continuity or a short to earth.
I tried 500 volts down each of the 4 wires between the ECU plug and the throttle plug (disconnect ECU, Radio and 10AS alarm unit (behind dash) before attempting such a thing! The 5v supply wire on the ECU plug had a small reading to the chassis so I got a new throttle loom only from "lukester0952" on ebay. Now I can't say for sure if it's fixed but I haven't had this issue since.
Interestingly, there are two throttle peddles for the TD5, later version had 3 tracks,early TD5s had 2 track. The 2 track version is discontinued and unavailable, would be interesting to know if the three track can be used on the earlier TD5s?
Post #1012606 25th Oct 2023 6:16pm
4RF RDS
My understanding is the three point pedal can be installed in earlier 10P models…. Perhaps others can confirm this.
Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #1012610 25th Oct 2023 6:21pm
VVS210
Thanks guys, has confirmed the advice I'd already given him. Have advised he gets in touch with Disco_Mikey who is not far from him & I'm sure will be able to get it sorted for him 👍
Post #1012625 25th Oct 2023 7:29pm
