Home > Puma (Tdci) > Key won’t turn
ChrisCSL
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Key won’t turn
I’ve got a problem where the key has not been turning all the way in the ignition barrel. It releases the steering lock, electrics come on (radio) but doesn’t turn the last bit to start the dash lights and fire up. Any ideas or just try changing the barrel?
Chris
Post #1012231 23rd Oct 2023 12:06pm
If the key physically won't rotate the last click it suggests to me a mechanical problem and I would think it is more likely to be the lock barrel than the electrical switch on the end, but it is possible that the switch could have failed in a way which is causing an obstruction.
The switch can be removed from the barrel, and you could then try operating the switch with a screwdriver and/or the barrel with the key, and the fault should be easy to locate.
Removing the switch without first removing the barrel is possible but exceptionally awkward, so it may be easier to remove the assembly first (also awkward since it is designed to be difficult for villains to remove).
Post #1012232 23rd Oct 2023 12:27pm
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
Hi Chris
I had a similar issue to yours. It turned out to be a roll pin had worked its way loose in the section between the key barrel and the ignition switch. When you have taken the part off the steering column you can carefully remove the cover as shown in the photo below (not mine) and check the mechanism inside.
Andy
Post #1012241 23rd Oct 2023 1:21pm
^ Useful knowledge, than you for posting. Thumbs Up
Post #1012252 23rd Oct 2023 2:35pm
ChrisCSL
Thanks gents.
job for tomorrow Thumbs Up
Post #1012278 23rd Oct 2023 4:45pm
