Home > Puma (Tdci) > Help stuck won’t start. |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 833 |
Are you in a position to unhitch the caravan to try a jump start? Or even better, can you get someone just to pull you with a tow strap to jump start you. 2008 2.4 110 Utility Station Wagon XS.
21st Oct 2023 1:37pm |
Rescue01 Member Since: 17 Jul 2015 Location: Aberdeen Posts: 99 |
Was going to ask if it would bump start. Had it stall long time ago and I’m sure it wouldn’t start while I was rolling but I’m on a hill so could try?
21st Oct 2023 1:42pm |
Definitely give it a go. Just don’t go too far down the hill if it puts you in any worse of a situation.
2nd gear would be my pick. Get a bit of momentum. If it starts then that would point me to your starter motor being at fault. 2008 2.4 110 Utility Station Wagon XS. |
21st Oct 2023 2:28pm |
Thanks. It’s pouring with rain and getting dark.It’s been a crap week already.Will start fresh in the morning in the dry.I’m thinking it’s the Ignition switch.
DT. |
21st Oct 2023 2:45pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2420 |
I would check earth points and lock/unlock with the fob a few times Puma 110" SW
22nd Oct 2023 10:25am |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2411 |
try locking and unlocking it a few times to begin with 2008 Santorini Black 110 XS USW (Sold)
2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
22nd Oct 2023 2:22pm |
Thanks for all the tips.
I suspect the ignition barrel is not turning all the way to the start position. Vehicle and caravan both moved after bump starting it. I’m back at work next week and no time to look at properly so it’s outside my local garage for them to sort. |
22nd Oct 2023 2:27pm |
Fantastic news the bump start worked..! 2008 2.4 110 Utility Station Wagon XS.
22nd Oct 2023 3:59pm |
Just to let you know that it was indeed the ignition barrel that was faulty and wouldn’t turn. All fixed and back to normal.
25th Oct 2023 3:53pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17432 |
Thank you, it is always good to hear that the problem has resolved and what the diagnosis was. It all helps build up the knowledge base.
25th Oct 2023 3:58pm |
