![]() | Home > Td5 > Whats up with these horns! |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 965 ![]() ![]() ![]() |
Its a BMW horn standard BMW horn plug less expensive to buy a BMW horn. Yes they do fail especially when not used occasionally. I have two Hellas in my 110 as the OE failed after 20 years. meep meep…
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 808 ![]() ![]() ![]() |
You might find that you can get the faulty horns working by giving them a sharp tap on a hard surface.... The coil inside might be stuck and that might free it off.
But your post raised another point for me.... Are you saying that there is a horn connection on each side of the car?... I'm pretty sure I only have one horn fitted to my 2005 TD5 |
My 99 build had a plug for a second horn on the passenger side but only one horn, I installed a second one
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17668 ![]() ![]() ![]() |
Td5 and Puma vehicles should all have wiring for two horns, one each side, a high note and a low note. I thought all vehicles had both but it may be that some poverty-spec models.didn'tternatively it may just be that the factory forgot to fit both sometimes.
All Td5 and Puma vehicles have a connector for the alarm sounder on the nearside, and all Td5 and very early Pumas also have the BBUS connection on the nearside. Later Pumas built without the BBUS need to have the wing harness swapped for a Td5 version if you want to fit a BBUS. |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1205 ![]() ![]() ![]() |
Yes there seems to some science suggesting two slightly different tones makes for a more effective horn, hence you can buy them in pairs.
One of the new horns I bought started working with a tap (thanks) but rather than butcher the one remaining plug thats fits on the one LR horn I had laying around, I will leave the new horn on the shelf. I did have the two different tones. I went from nothing to everything. Now I just to remember to use them. |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2667 ![]() ![]() ![]() |
@op, you need this
![]() https://www.instagram.com/reel/CyPXmhKRt9N/ -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5257 ![]() ![]() |
also i believe the horn is the same unit used in later metros and MGFs. I know the MGFs use the twin setup. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
