![]() | Home > Technical > Air con condenser |
andre.prum Member Since: 24 Feb 2014 Location: Bridel Posts: 8 ![]() ![]() ![]() |
Thanks Darren for your advice.
Is there any way to check the valve without dismounting it ? |
Yes, the operating lever is on the outside of the valve and is connected to the heater control knob by a cable. Rotate the knob all the way to cold and then see if there's any travel left on the operating lever. If there is then the valve isn't being closed properly. You might be able to adjust the cable (can't remember what the end fitting is without looking) but some folks on here have even fitted springs to the lever to assist with closing the valve. Darren
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2322 ![]() ![]() ![]() |
Difficult to compare as my air con hasn't been working for a couple of years! But it's certainly performing well now > 110 XS Double Cab |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 ![]() ![]() ![]() |
Nice find on the condenser Hank! Seems to be some AC experts on this thread, so I'll put this out there. My condenser fan runs non stop. I have been unplugging it every fall to stop it from running through the winter. Had my local go through and check everything, no luck. Anyone have any thoughts on where to start? it's a Landrover thing...
my renovation thread: http://www.defender2.net/forum/topic40792.html |
jmccoy55555 Member Since: 01 Dec 2021 Location: Surrey Posts: 5 ![]() ![]() ![]() |
Linked one looks sold out.
This one https://www.ebay.co.uk/itm/363440780259 looks the same.... Would anyone have the dimensions of the OEM one handy? |
Stanyx Member Since: 30 Sep 2015 Location: Limburg Posts: 5 ![]() ![]() ![]() |
Hi there, found 2 alternatives for the OE condensor unit, now priced at £700:
NRF Easy Fit 350489 Condensor, airconditioning 15,5mm, 15,5mm, 675mm art: 350489 MAHLE ORIGINAL (LR025985) 16mm, 15,5mm, 655mm art: AC 1084 000S Hope this helps, Stéphane |
Trendkill110 Member Since: 04 Sep 2021 Location: Yorkshire Posts: 73 ![]() ![]() ![]() |
Hello folks!
Does anyone have a link for the condensor Hank bought and fitted? None of the above links are working anymore. Upgrading the intercooler next week so going to do this at the same time. TIA 👍🏻 |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2206 ![]() ![]() ![]() |
https://www.ebay.co.uk/itm/115768660522?mk...media=COPY
Same part number as the one I bought but might be worth a message to double check.fitment. |
