Home > Technical > Air con condenser
Page 1 of 4 1234>
jst
Air con condenser
Does anyone know where you can get a decent quality replacement condenser for the ac. After just the condenser part, not surround frame or fan needed. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #832213 20th May 2020 4:14pm
landy andy
They only come complete with surround and fan. I got a britpart (spit) one years ago, and it looked exactly the same as original, fitted great, worked and lasted.
Could you get yours record like they do with rads?
Post #832224 20th May 2020 4:48pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
There doesn’t seem to be an aftermarket source for these, even the britpart item is OEM.
Also because the Defender has finished production the price seems to have gone up!As I think it is unique to the Defender.
I’m not sure if you could make something else fit.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #832261 20th May 2020 7:38pm
bankz5152
They cost £420. No one else makes one. You cant make another fit without replacing all the AC pipe work.
Allisport considered one but never made it.
Post #832267 20th May 2020 8:00pm
jst
Oh.
Thanks for replies. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #832298 20th May 2020 10:42pm
bankz5152
I was just as down when my condensor totally failed a few years ago. They are so brittle and thin you cant even find take off or scrapped ones. I can say after i replaced it the AC now stays in for at least 8 months and is considerably colder. So well worth it.
Just got to find the other pin leak....
Post #832301 20th May 2020 11:06pm
landy andy
Ever since replacing mine I’ve had a fine mesh behind the grill, to save paying out again. Twisted Evil
Post #832327 21st May 2020 8:09am
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Speak to Robin at Duckworth Parts. (Brilliant service)
He’s got a few take off condensers.
Replaced mine this morning, all gassed up and 🥶!
Post #832378 21st May 2020 1:50pm
Thon
Mine has lost most of its fins and is held together with cable ties - they seem to be ultra vulnerable to salt and vaporise in a few short years. Whenever I go through deep water I end up with a festoon of unfolded aluminum fin hanging down from behind the grille. It still works though which makes me loath to replace it but don't want to dump the gas because I'm too tight to bow to the inevitable. I think it's a job for this summer.
Post #832380 21st May 2020 2:03pm
jst
New one ordered, thanks everyone. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #832695 22nd May 2020 8:33pm
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Do you mind me asking where you got yours from & at what cost? Ours is held together with cable ties & needs replacing sooner rather than later.
Post #833313 25th May 2020 4:05pm
jst
Brookwells, Bovey tracy POC - Justin Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #833352 25th May 2020 7:21pm
Timcat
Thumbs Up
Post #833404 26th May 2020 8:02am
wyvern
Hi all
anyone found a more reasonable pricing for a condenser ?
LR025985
The only ones I have found are still in the £400 range ... Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #903876 19th May 2021 10:39am
Timcat
Interested in one also Gary, ours is about shot.
Post #903879 19th May 2021 11:09am
Page 1 of 4 1234>
