Home > Puma (Tdci) > Turbo whistle |
Is it possible for a turbo to whistle a bit intermittently (e.g. after a remap ) without being b*ggered?
Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
20th Nov 2011 11:06am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
A turbo should only whistle under load, are you sure it's the turbo and not a leaking exhaust manifold? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
20th Nov 2011 12:32pm |
It only whistles under load, mostly in second gear. Turbo would seem more likely (?) as the remap has only been on two days (no whistle before). Really p*ssed off, as I have just put the factory map back on again and the whistle is still there - I guess something is broken now Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... Last edited by ZeDefender on 20th Nov 2011 12:58pm. Edited 1 time in total |
20th Nov 2011 12:38pm |
No engine mods, except an Alive remap done on Thursday. The remap had some issues (notably vibration around 2000rpm) but I was going to get them sorted out on Monday (too late, I fear). You're right - I have fitted a noise blanket but it's effect is moderate - the whistling is so loud I would definitely have noticed it before and it's too loud to be ignored... Oh - and it only seems to be when the engine is hot. Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
20th Nov 2011 1:03pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Sounds very much as mentioned above then. Manifolds are known to warp on some occasions. Maybe it was on its way out and loading the map has just finished it off.
Glyn |
20th Nov 2011 1:11pm |
Thanks. Can you give me any idea how serious it is to fix a turbo manifold? I will take it to LR in Landsberg and hopefully get some payback for the other dealer being so ... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
20th Nov 2011 1:50pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
If it is the Turbo manifold that has warped then Nakatanenga do an annealed copper gasket to replace the OEM one. Remember to replace the studs and nuts at the same time.
Is there a drop in power or just a more audible turbo whistle? With the Alive remap the engine is definitely quieter than the standard tune. So with the addition of a quieter engine and the blanket then it may be reasonable to assume the noise was always there, just that you couldn't hear it pre remap? It is easy enough to check the turbo manifold for signs of a leak, just look for a build up of soot from the area around the manifold. If there is none there, you don't have a leaking manifold. Brian. |
20th Nov 2011 2:41pm |
Power seems okay, just the whistle for now but its definitely new (took blanket off and original map) and pretty loud. Need to figure out where the turbo is now - think it's right front (UK driver's side) with the big-ass hose coming back into it (yup - idiot question ) Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
20th Nov 2011 2:49pm |
On a RHD defender the turbo is located on the offside of the engine block underneath a heat shield.
Click image to enlarge Click image to enlarge Brian. |
20th Nov 2011 2:58pm |
Yup - the rusty bit - thanks. So I will have to take the shield off to see it properly. Drat Is it only the lower/exhaust end gasket (square) that goes? Cheers, Matt p.s. nice diagrams Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
20th Nov 2011 3:12pm |
No, it is the manifold depicted as A in the bottom diagram. And here is the link for the gasket:
http://www.defender2.net/forum/topic6130.html Brian. |
20th Nov 2011 3:18pm |
Aha! The one you almost can't see Makes sense if it's a centrifugal turbine Thanks. Have you ever changed one? If so, how painful is it? I'm always eager to learn new tricks and I'd rather use the improved Nak. version but it looks as if you have to get the whole exhaust manifold off? I guess I'd better let LR do it under warranty... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
20th Nov 2011 4:06pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
You've got something other than if or when the gearbox might fail now Steve.
20th Nov 2011 4:51pm |
Thank you MOG. I didn't even notice changing gear whilst listening for the turbo whine! God is merciful Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
20th Nov 2011 5:19pm |
