Home > Puma (Tdci) > Turbo whistle
ZeDefender
Turbo whistle
Is it possible for a turbo to whistle a bit intermittently (e.g. after a remap Whistle ) without being b*ggered?
Matt Tell someone you love them today because life is short.
Post #101142 20th Nov 2011 11:06am
Naks
Re: Turbo whistle
A turbo should only whistle under load, are you sure it's the turbo and not a leaking exhaust manifold? --
Post #101152 20th Nov 2011 12:32pm
ZeDefender
Re: Turbo whistles after remap
It only whistles under load, mostly in second gear. Turbo would seem more likely (?) as the remap has only been on two days (no whistle before). Really p*ssed off, as I have just put the factory map back on again and the whistle is still there - I guess something is broken now Big Cry
Post #101153 20th Nov 2011 12:38pm
Glynparry25
What mods have you done?
Mine as standard whistled...... Am I right in believing from another thread that you have fitted a noise blanket?
Could just be that you haven't noticed it before?
Glyn Dog Sheep
Post #101155 20th Nov 2011 12:57pm
ZeDefender
Glyn Dog Sheep
No engine mods, except an Alive remap done on Thursday. The remap had some issues (notably vibration around 2000rpm) but I was going to get them sorted out on Monday (too late, I fear).
You're right - I have fitted a noise blanket but it's effect is moderate - the whistling is so loud I would definitely have noticed it before and it's too loud to be ignored...
Oh - and it only seems to be when the engine is hot.
Post #101156 20th Nov 2011 1:03pm
Glynparry25
Sounds very much as mentioned above then. Manifolds are known to warp on some occasions. Maybe it was on its way out and loading the map has just finished it off.
Glyn Dog Sheep
Post #101157 20th Nov 2011 1:11pm
ZeDefender
Glyn Dog Sheep
Thanks. Can you give me any idea how serious it is to fix a turbo manifold?
I will take it to LR in Landsberg and hopefully get some payback for the other dealer being so Censored ... Tell someone you love them today because life is short.
Post #101159 20th Nov 2011 1:50pm
Lorryman100
If it is the Turbo manifold that has warped then Nakatanenga do an annealed copper gasket to replace the OEM one. Remember to replace the studs and nuts at the same time.
Is there a drop in power or just a more audible turbo whistle? With the Alive remap the engine is definitely quieter than the standard tune. So with the addition of a quieter engine and the blanket then it may be reasonable to assume the noise was always there, just that you couldn't hear it pre remap? It is easy enough to check the turbo manifold for signs of a leak, just look for a build up of soot from the area around the manifold. If there is none there, you don't have a leaking manifold.
Brian.
Post #101165 20th Nov 2011 2:41pm
ZeDefender
Brian.
Power seems okay, just the whistle for now but its definitely new (took blanket off and original map) and pretty loud.
Need to figure out where the turbo is now - think it's right front (UK driver's side) with the big-ass hose coming back into it (yup - idiot question Embarassed ) Tell someone you love them today because life is short.
Post #101167 20th Nov 2011 2:49pm
Lorryman100
On a RHD defender the turbo is located on the offside of the engine block underneath a heat shield.
Brian.
Post #101169 20th Nov 2011 2:58pm
ZeDefender
Brian.
Yup - the rusty bit - thanks.
So I will have to take the shield off to see it properly. Drat Sad
Is it only the lower/exhaust end gasket (square) that goes?
Cheers,
Matt
p.s. nice diagrams Thumbs Up Tell someone you love them today because life is short.
Post #101172 20th Nov 2011 3:12pm
Lorryman100
No, it is the manifold depicted as A in the bottom diagram. And here is the link for the gasket:
http://www.defender2.net/forum/topic6130.html
Brian.
Post #101173 20th Nov 2011 3:18pm
ZeDefender
Brian.
Aha! The one you almost can't see Wink Makes sense if it's a centrifugal turbine Embarassed
Thanks. Have you ever changed one? If so, how painful is it?
I'm always eager to learn new tricks and I'd rather use the improved Nak. version but it looks as if you have to get the whole exhaust manifold off? I guess I'd better let LR do it under warranty... Tell someone you love them today because life is short.
Post #101182 20th Nov 2011 4:06pm
Happyoldgit
You've got something other than if or when the gearbox might fail now Wink Steve.
http://forums.lr4x4.com
Post #101185 20th Nov 2011 4:51pm
ZeDefender
Thank you MOG. I didn't even notice changing gear whilst listening for the turbo whine!
God is merciful Laughing Tell someone you love them today because life is short.
Post #101189 20th Nov 2011 5:19pm
